(API) Insert the assembly into presentation (Inventor) via API
I created a presentation document
Now I would need to insert the assembly via API.
Is there a command to do this?
YuhanZhang
Unfortunately till now there are no presentation APIs exposed yet, but as a workaround you can try below VBA code to insert a scene for a new presentation document:
Sub InsertToPrestention()
Dim oCM As CommandManager
Set oCM = ThisApplication.CommandManager
oCM.ClearPrivateEvents
Dim sFile As String
sFile = "C:\Temp\Block.iam"
oCM.PostPrivateEvent kFileNameEvent, sFile
Dim oDoc As PresentationDocument
Set oDoc = ThisApplication.Documents.Add(kPresentationDocumentObject)
End Sub
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Tank YuhanZhang .
I entered your suggestion and works properly.
For vb net place the code I used.
Dim oCM As Inventor.CommandManager
oCM = invApplication.CommandManager
oCM.ClearPrivateEvents()
Dim sFile As String = "C:\temp\test.iam"
Call oCM.PostPrivateEvent(Inventor.PrivateEventTypeEnum.kFileNameEvent, sFile)
Dim oDoc2 As PresentationDocument
oDoc2 = invApplication.Documents.Add(Inventor.DocumentTypeEnum.kPresentationDocumentObject)
oDoc2.SaveAs(namefile & "_P.IPN", False)
