To Retrieve Parent's BOM Structure
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 11
RoyWickrama_RWEI
In my rule, I have a hard time to retrieve the BOM Structure of parent which I need as the ultimatum fix to continue.
Sample model attached here to.
I request someone help me.
Public Class RWEI_0010BOM
	Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt"
Sub Main
	Dim oAssy_ThisDoc As AssemblyDocument
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim iL_NO As String = "0010-BOM"
	oDelete_ex_Notepad(oTextSave, iL_NO)
	Dim HL1_Prefix As String = "FILE REFERENCE TREE RAN FROM: "
	oHL1 = HL1_Prefix & oDoc.FullFileName
	oWrite_HeaderLines(oTextSave, oHL1)
	Dim iL_Name As String = "All Occurrences with BOM Structure"
	Dim oHL2 As String = "Rule " & iL_NO & ": " & iL_Name
	oWrite_HeaderLines(oTextSave, oHL2)
	Dim oDashes As String = ""
	For i = 1 To Len(oHL2)
	oDashes = oDashes & "-"
	Next i
	Dim oHL3 As String = oDashes
	oWrite_HeaderLines(oTextSave, oHL3)
	Dim oHL4 As String = ""
	oWrite_HeaderLines(oTextSave, oHL4)
Dim oBOM As BOM
oBOM = ThisApplication.ActiveDocument.ComponentDefinition.BOM
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Unnamed")'Accesing to Model data Column
'In English__"Unnamed"_"Structured"_"Parts Only"__In Spanish__"Sin nombre"_"Estructurado"_"Solo piezas"
  Call ListItems(oBOMView.BOMRows, 0)
Process.Start("Notepad.exe", oTextSave)
End Sub
Sub ListItems(Rows As BOMRowsEnumerator, indent As Integer)
    Dim oBOMRow As BOMRow
    For Each oBOMRow In Rows
			Dim oDef As ComponentDefinition
			oDef = oBOMRow.ComponentDefinitions(1)
			Dim oLFN  As String
			oLFN  = oDef.Document.Displayname
			Dim oDocFile As Document
			oDocFile = oDef.Document
			If oDocFile.IsModifiable = True Then
				Dim oBOMStructnumber As String
			    oBOMStructnumber = oBOMRow.BOMStructure
				Dim BOM_Structure As String
				If oBOMStructnumber <> 51972 Then
				If oBOMStructnumber = 51969 Then BOM_Structure = "Default"
				If oBOMStructnumber = 51974 Then BOM_Structure = "Inseparable"
				If oBOMStructnumber =  51970 Then BOM_Structure = "Normal"
				If oBOMStructnumber = 51971 Then BOM_Structure = "Phantom"
				If oBOMStructnumber =  51973 Then BOM_Structure = "Purchased"
				If oBOMStructnumber = 51972 Then BOM_Structure = "Reference"
				If oBOMStructnumber = 51975 Then BOM_Structure = "The Structure Type varies amongst references"
				Dim Parent As Document = oDocFile.ReferencingDocuments.Item(1)
				'To retrieve BOM Structure of parent
				Dim oParentDocFile As Document
				oParentDocFile = Parent		'oDef.Document
				MessageBox.Show("Message1", "Title")
				BOM_Parent = oParentDocFile.BOMStructure		'oParentDocFile.Definition.BOMStructure
				MessageBox.Show("Message2", "Title")
				    If Not oBOMRow.ChildRows Is Nothing Then
				        Call ListItems(oBOMRow.ChildRows, indent + 1)
					Dim oPhantomPart_ParentOfPhantomPart As String = ""
					If Right(oLFN, 3) = "ipt" And BOM_Structure = "Phantom" Then
						'Do nothing
					Else
						If Right(oLFN, 3) = "iam" And BOM_Structure = "Phantom" Then
							'Do nothing
						Else If Right(oLFN, 3) = "ipt" And BOM_Structure = "Phantom" Then
							oPhantomPart_ParentOfPhantomPart = oLFN & "$" & Parent.DisplayName
						Else
						   	oName_Parent = BOM_Parent & "$" & Parent.DisplayName & "$" & BOM_Structure & "$" & oLFN
							oWrite_Data(oTextSave, oName_Parent)
    Next
End Sub
	Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String)
	oWrite = System.IO.File.AppendText(oTextSave)
	oWrite.WriteLine(oHeaderLine)
	oWrite.Flush()
	oWrite.Close
	End Sub
	Sub oWrite_Data(oTextSave As String, oData As String)
	oWrite.WriteLine(oData)
	oWrite.Flush()
	oWrite.Close
	End Sub
	Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String)		'To delete oTextSave if existing.
	If System.IO.File.Exists(oTextSave) = True Then
	System.IO.File.Delete(oTextSave)
	End Sub
End Class
Replies (10)
Message 2 of 11
YuhanZhang
You can try to change the like below:
to
BOM_Parent = oParentDocFile.ComponentDefinition.BOMStructure
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 11
RoyWickrama_RWEI
That is the line of code I want.
This most probably be accepted as a solution, but let me work on this. I will get back to you.
Message 4 of 11
RoyWickrama_RWEI
Thanks Yuhan.
It is a solution. But, that rule is not giving me the desired results.
I have another nice rule (attached here to and available from within the sample assembly also attached here to) that is very good and flexible. But. I have some issues with that rules:
ISSUE-1: Need to get data here for the BOM Structure of Parent
ISSUE-2: Reference Bom structure assigned in assembly level is not captured.
I spent weeks without success and I request you help me get around these issues
Message 5 of 11
YuhanZhang
Just modified your iLogic code, and you can try if it works as expected:
Public Class RWEI_0001A
Sub Main()
	'Accessing Assembly Components $ https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
	Dim iL_NO As String = "BOM-XX WIP"
	Dim iL_FullName As String = "Rule " & iL_NO & ": " & iL_Name
	oHL1 = "FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName
	oHL2 = iL_FullName
	For i = 1 To Len(iL_FullName)
	Next i
	oWrite_DashLine(oTextSave, oDashes)
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
	Dim BOM_Parent As String
    For Each oOcc In Occurrences
        ' Print the name of the current occurrence.
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
		oFFN_cw_EXT = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName	'cw file extension
		oLFN_cwExt = oDoc_LocalName_WExt(iL_NO, oFFN_cw_EXT)
		BOM_Structure_Return = Func_BOM_Structure(iL_NO, oOcc)
			'specify word splitting characters "space" and "dash"
			Dim Separators() As Char = {"*"c}
			Sentence = BOM_Structure_Return
			Words = Sentence.Split(Separators)
			i = 0
			For Each wrd In Words
			'MessageBox.Show("Word Index #" & i & " = " & Words(i))
			i += 1
			Next
		BOM_Structure = Words(0)
		oOccurrence_FFN = Words(1)
'		oParent = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
		Try
			Dim oParentocc As ComponentOccurrence
			oParentocc = oOcc.ParentOccurrence
			BOM_Parent = Func_BOM_Structure("",oParentocc)
			docFile = oParentocc.Definition.Document
		    oParentFFN = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
		    oParent = System.IO.Path.GetFileName(docFile.FullFileName)
		Catch
			oParentFFN = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName)
			oParent = System.IO.Path.GetFileName(oOcc.Parent.Document.DisplayName)
		End Try
'*************************** BOM_Parent BOM STRUCTURE Parent******************
		BOM_Structure_Parent = "BOM Structure of Parent: " & BOM_Parent
'***************************BOM Structure Parent**********************
		oData_X = BOM_Structure_Parent & " $ " & oParent & "$" & oLFN_cwExt & "$" & oOcc.Name & "$" & "Level-" & Level & "$" & BOM_Structure
'		oData_X = oParent & "$" & oOcc.Name & "$" & "Level-" & Level & "$" & BOM_Structure
'		oData_X = oLFN_cwExt & "$" & oFFN_cw_EXT & "$" & BOM_Structure & " " & oParent & "$" & oOcc.Name & "$" & "Level-" & Level
		oWrite_Data(oTextSave, oData_X)
	Next
End Sub
	Function oDoc_LocalName_WExt(iL_NO As String, oFFN_cw_EXT As String)
	oName_Sub = "oDoc_LocalName_WExt"
	oTitle = iL_NO & " $ SUB: " & oName_Sub
	oPos = Len(oFFN_cw_EXT) - InStrRev(oFFN_cw_EXT, "\", -1)
	oName_Local_cw_Ext = Right(oFFN_cw_EXT, oPos)
	Return oName_Local_cw_Ext 'Local file name complete with extension
	End Function
	Function Func_BOM_Structure(iL_NO As String, oCompOcc As ComponentOccurrence)
		oName_Sub = "BOM_Structure"
		Dim oOccurrence As ComponentOccurrence
		oFFN_X = oCompOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
		BOM_X = oCompOcc.BOMStructure 'oCompOcc.Definition.BOMStructure
		If BOM_X = BOMStructureEnum.kDefaultBOMStructure Then BOM_Structure = "Default"
		If BOM_X = BOMStructureEnum.kNormalBOMStructure Then BOM_Structure = "Normal"
		If BOM_X = BOMStructureEnum.kReferenceBOMStructure Then BOM_Structure = "Reference"
		If BOM_X = BOMStructureEnum.kPhantomBOMStructure Then BOM_Structure = "Phantom"
		If BOM_X = BOMStructureEnum.kPurchasedBOMStructure  Then BOM_Structure = "Purchased"
		If BOM_X = BOMStructureEnum.kInseparableBOMStructure  Then BOM_Structure = "Inseparable"
		If BOM_X = BOMStructureEnum.kVariesBOMStructure Then BOM_Structure = "Varies"
		oDoc_LocalName_WExt(iL_NO, oFFN_X)
		'BOM_Structure = oDoc_LocalName_WExt(iL_NO, oFFN_X) & " <- " & BOM_Structure & "(BOM STATUS: Default)"
		Dim BOM_Structure_Return As String = BOM_Structure & "*" & oFFN_X
		Return BOM_Structure_Return
	End Function
Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String)
	Return oOcc.Parent.Document.DisplayName
End Function
'Process.Start("Notepad.exe", oTextSave)
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
Sub oWrite_DashLine(oTextSave As String, oDashes As String)
	oWrite.WriteLine(oDashes)
	oWrite.Flush()
	oWrite.Close
End Sub
End Sub
End Class
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 6 of 11
RoyWickrama_RWEI
Thanks Yuhan Zhang. This time it is fully functioning.
You did a great help: I could never do this (at least for a year from now).
Again, thank you Sir.
Note: I was trying to do with other rule. That is also now kind of promising. I will let you know the results.
Message 7 of 11
RoyWickrama_RWEI
Hi Yuhan, I have a one more question:
I need to retrieve the BOM Structure of the current document (main assembly in which I run the rule), just as a formality.
Could you reply me. Thanks.
Message 8 of 11
RoyWickrama_RWEI
Hi Yuhan;
I think. I got it.
Dim doc = ThisDoc.Document
oBOM = doc.ComponentDefinition.BOMStructure
MessageBox.Show("Message: " & oBOM, "Title")
Message 9 of 11
RoyWickrama_RWEI
Hi Yuhan;
Thanks again. I keep doing well with your code. I came across with a situation where my document and parent-of-document relationship fails when the BOM structure of the parent is phantom.
In this case (if the parent's BOM structure is phantom), the parent of the document is the parent-of-parent.
I keep trying with the code shown below without success. Could you take a look at, please. Thanks. A fake model is attached.
Sub Main()
	oHL2 = iL_FullName
	Next i
	oHL3 = ""
End Sub
	Dim oParent_BOM_Structure As String
		If oOcc.ReferencedDocumentDescriptor.ReferencedDocument.IsModifiable = True Then
			oOccFFN_cw_EXT = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName	'cw file extension
			oOccLFN_cwExt = oFnOccc_LocalName_WExt(iL_NO, oOccFFN_cw_EXT)
			oOcc_BOM_Structure = oFn_BOM_Structure_Occ(iL_NO, oOcc)
			Try
				oParent_BOM_Structure = oFn_BOM_Structure_Occ("",oParentocc)
			Catch
			End Try
			If Level = 1 Then oParent_BOM_Structure = oFn_OccLevel1_BomStructure()
			If oParent_ofParent = "" Then oParent_ofParent = "oParent_ofParent - Missing"
			oData_X = oParent_ofParent & " $ " & oParent_BOM_Structure & " $ " & oParent & " $ " & oOccLFN_cwExt & " $ " & oOcc.Name & " $ " & "Level-" & Level & " $ " & oOcc_BOM_Structure
	'		oData_X = oParent & "$" & oOcc.Name & "$" & "Level-" & Level & "$" & oOcc_BOM_Structure
	'		oData_X = oOccLFN_cwExt & "$" & oOccFFN_cw_EXT & "$" & oOcc_BOM_Structure & " " & oParent & "$" & oOcc.Name & "$" & "Level-" & Level
	Next
End Sub
	Function oFnOccc_LocalName_WExt(iL_NO As String, oOccFFN_cw_EXT As String)
	oName_Sub = "oFnOccc_LocalName_WExt"
	oPos = Len(oOccFFN_cw_EXT) - InStrRev(oOccFFN_cw_EXT, "\", -1)
	oName_Local_cw_Ext = Right(oOccFFN_cw_EXT, oPos)
	End Function
	Function oFn_BOM_Structure_Occ(iL_NO As String, oCompOcc As ComponentOccurrence)
		oName_Sub = "oOcc_BOM_Structure"
'		Dim oOccurrence As ComponentOccurrence
		If BOM_X = BOMStructureEnum.kDefaultBOMStructure Then oOcc_BOM_Structure = "Default"
		If BOM_X = BOMStructureEnum.kNormalBOMStructure Then oOcc_BOM_Structure = "Normal"
		If BOM_X = BOMStructureEnum.kReferenceBOMStructure Then oOcc_BOM_Structure = "Reference"
		If BOM_X = BOMStructureEnum.kPhantomBOMStructure Then oOcc_BOM_Structure = "Phantom"
		If BOM_X = BOMStructureEnum.kPurchasedBOMStructure  Then oOcc_BOM_Structure = "Purchased"
		If BOM_X = BOMStructureEnum.kInseparableBOMStructure  Then oOcc_BOM_Structure = "Inseparable"
		If BOM_X = BOMStructureEnum.kVariesBOMStructure Then oOcc_BOM_Structure = "Varies"
		'oOcc_BOM_Structure = oFnOccc_LocalName_WExt(iL_NO, oFFN_X) & " <- " & oOcc_BOM_Structure & "(BOM STATUS: Default)"
		Dim BOM_Structure_Return As String = oOcc_BOM_Structure
	End Function
End Function
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
Function oFn_OccLevel1_BomStructure()
	If oBOM = BOMStructureEnum.kDefaultBOMStructure Then oOcc_BOM_Structure = "Default"
	If oBOM = BOMStructureEnum.kNormalBOMStructure Then oOcc_BOM_Structure = "Normal"
	If oBOM = BOMStructureEnum.kReferenceBOMStructure Then oOcc_BOM_Structure = "Reference"
	If oBOM = BOMStructureEnum.kPhantomBOMStructure Then oOcc_BOM_Structure = "Phantom"
	If oBOM = BOMStructureEnum.kPurchasedBOMStructure  Then oOcc_BOM_Structure = "Purchased"
	If oBOM = BOMStructureEnum.kInseparableBOMStructure  Then oOcc_BOM_Structure = "Inseparable"
	If oBOM = BOMStructureEnum.kVariesBOMStructure Then oOcc_BOM_Structure = "Varies"
End Function
End Sub
End Class
Message 10 of 11
YuhanZhang
I don't see any component in your sample data has Phantom BOM structure, and also your code below will always cause to output the "oParent_ofParent - Missing" in the result, which seems not meaningful:
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 11
RoyWickrama_RWEI
Thanks Yuhan for getting back to me.  (REQUEST HELP AGAIN!)
The latest rule is attached here to is fine. But, it gives me n error when I run the same in Inventor 2018 (and 2015 as well). I can't fix this issue. Could you kindly take a look at this, please.
	'https://adndevblog.typepad.com/manufacturing/2013/11/iterate-structured-bomview.html
Sub Main()
	oHL2 = iL_FullName
	Next i
	oHL3 = ""
	oAsmDoc.Save
	Dim oParent_ofParent_atL3 As String = ""
	Dim oParent_ofParent_atL4 As String = ""
	Dim oParent_ofParent_atL5 As String = ""
	Dim oLevel_Request As Integer = 1
	'oLevel_Request = InputBox("Level for Data Record: ", "USER INPUT REQUEST", oLevel_Request)
	Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, 1, oParent_ofParent_atL3, oParent_ofParent_atL4, oParent_ofParent_atL5, oLevel_Request)
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, j As Integer, oParent_ofParent_atL3 As String, oParent_ofParent_atL4 As String, oParent_ofParent_atL5 As String, oLevel_Request As Integer)
		If Level = 1 Then
			oParent_ofParent = "Not Applicable"
			oParent_ofParent_atL3 = "This Document"
	        If oOcc.DefinitionDocumentType = kPartDocumentObject Then
	        Else	'If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
				oParent_ofParent_atL3 = oFn_BrowserName(oOcc)
			Call TraverseAssembly(oOcc.SubOccurrences, Level+1, j+1, oParent_ofParent_atL3, oParent_ofParent_atL4, oParent_ofParent_atL5, oLevel_Request)
		If Level = 2 Then 'oParent_ofParent_atL3 Processing
			oParent_ofParent = "This Document"		'for Level 2 only
				oParent_ofParent_atL4 = oFn_BrowserName(oOcc)
		If Level = 3 Then
			oParent_ofParent = oParent_ofParent_atL3		'for Level 2 only
				oParent_ofParent_atL5 = oFn_BrowserName(oOcc)
		If Level = 4 Then
			oParent_ofParent = oParent_ofParent_atL4
				oParent_ofParent_atL6 = oFn_BrowserName(oOcc)
		If Level = 5 Then
			oParent_ofParent = oParent_ofParent_atL5
				oParent_ofParent_atL7 = oFn_BrowserName(oOcc)
	Try
	Catch
	End Try
'	If Level = oLevel_Request Then
		oData_X = oParent_ofParent & " $ " & oAssy_to_Next & "$" & oParent_BOM_Structure & " $ " & oParent & " $ " & oOcc.Name & " $ " & "Level-" & Level & " $ " & oOcc_BOM_Structure
'	End If
	Next oOcc
End Sub
	End Function
End Function
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
End Function
End Sub
Function oFn_BrowserName(oOcc As ComponentOccurrence)
	' Get the model browser
	Dim oPane As BrowserPane
	oPane = oAsmDoc.BrowserPanes.Item("Model")
	    Dim oSubAssyNode As BrowserNode
	    oSubAssyNode = oPane.GetBrowserNodeFromObject(oOcc)
		Dim oBrowserName_Old As String
		oBrowserName_Old = oSubAssyNode.NativeObject.Name
		Return oBrowserName_Old
End Function
End Class
