How to use iLogic to return a filename of a derived part?
Message 1 of 10
I'm using a derive in a model to make a design (picture 1).
For the moment I have some troubles with using iLogic rule.
First thing:
I want to get the filename without filepath (I prefer also without extension) of this derived part by using iLogic rule.
The next thing:
I want to have this filename in an User parameter.
All I have found is:
modelFileNamewithoutextension = IO.Path.GetFileNameWithoutExtension(modelFullFileName)
But this is the filename of the model... Who can help me please?
picture 1picture 1
Accepted solutions (3)
Replies (9)
Message 2 of 10
Thomas_Savage
Hello @Anonymous
This would be better posted in the Inventor Customization forum.
I have asked for this to be moved for you.
I hope you get a solution to your problem there.
Thomas.
Thomas Savage
Design Engineer
Message 3 of 10
Sergio.D.Suárez
hi, try this ilogic code greetings
Dim refdoc As Document = ThisDoc.Document.ReferencedDocuments.Item(1)
Dim onext As String = refdoc.DisplayName
Dim offext As String = IO.Path.GetFileNameWithoutExtension(onext)
MessageBox.Show(onext, "with extension")
MessageBox.Show(offext, "without extension")
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 10
Hi, thanks.
Running this rule gives me the same result. Both is without ext.
Message 5 of 10
Sergio.D.Suárez
hi, if it's good for you, you can mark my answer as a solution, greetings
Mechanical Designer
Message 6 of 10
One thing is solved.
But can you also help me with the other thing:
How can I get this filename into an User Parameter?
Message 7 of 10
Sergio.D.Suárez
You must first create user parameters, such as text.
then you must load those parameters to the rule, here is an example.
Name1 = onext
Name2 = offext
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
Mechanical Designer
Message 8 of 10
Thank you very much!
It's solved for me.
Greetings Jan
Message 9 of 10
raphael.widmann5DUKP
Edit: replayd not to Jan but to Sergio...
Message 10 of 10
Hello guys,
as Jan mentioned, the result of both (onext/offext) is the same. In my case, I have the following result:
First the code:
'Ermitteln der Materialangabe aus Unterkomponente
	'Auslesen der Basiskomponente
	Dim basepart As Document = ThisDoc.Document.ReferencedDocuments(1)
	basepart_name = basepart.DisplayName
	basepart_filename = IO.Path.GetFileName(basepart_name)
	'Auslesen der Materialangabe
	mat_variant = Parameter.Value("GER_BEL_CAD10063859.ipt", "Materialvariante")
	'Zuweisen der Materialangabe zu Material
	iProperties.Material = mat_variant
'Testausgabe
MessageBox.Show(mat_variant.ToString & " - " & basepart_filename, "TEST")
My MessageBox shows the following:
So you wont get the filename with it, but the displayname at the browser (maybe on in most cases this is the same, but not on my config of the modelbrwoser).
What I exactly need is this:
I've tried different things, ending up with this:
oDoc = ThisApplication.ActiveDocument
If oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count > 0
Dim oDerComp As DerivedPartComponent = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
Dim oDerDef As DerivedPartDefinition = oDerComp.Definition.Name
But this is also giving just hte name at the modelbrowser...
Do you have any Ideas, how to get the filename?
Thanks very much in advance!
BR
Raphael
