Change visiblity depending on material asigned
In an assebly, I want to only show on screen parts with a defined material only.
I.e. All parts that the material is set to "steel" are visible / all other parts are not visible
OR
All parts that the material is set to "steel" or "glass" are visible / all other parts are not visible
Thanks for you help
Mike
CCarreiras
Hi!
There's no automatic View filters based in properties, but you can create several View Representations mannually to achieve what you said.
CCarreiras
Is there some Ilogic that could do this? (I am new to Ilogic so am not sure what you can do or how to do it!)
CCarreiras
I don't think so.
iLogic programing is a way  that uses inventor capabilities. Doesn't add new features that do not exist already in the inventor, simply you can automate them.
i mean, directly not, but... you can start trying something like this:
IF iProperties.MaterialOfComponent("partA:1")="Steel" THEN
Component.Visible("PartA:1") =true
ELSE
Component.Visible("PartA:1") =False
END IF
CCarreiras
MechMachineMan
Public Class PVars
Shared oMatl As String = InputBox("Conatining Phrase of Mat'l to Isolate", "ISOLATE", "Steel")
Public Sub TraverseAssemblySample()
Dim PVar As New PVars ' Get the active assembly. Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Debug.Print oAsmDoc.DisplayName ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, _ Level As Integer) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences If oOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Material").Value Like "*" & PVar.oMatl & "*"
'oOcc.Visible = False
Else
'oOcc.Visible = True
If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) End If Next End Sub
End Class
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
LukeDavenport
Hi Mikey,
This looks like a perfect job for my addin on the Exchange App Store:
Youtube video:
https://www.youtube.com/watch?v=qem8o-R2mqQ
App Store:
https://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3aviewr...
It does the exact thing you describe - allows as many assembly filters as you like to be created and saved for iProperties (including Material), that can be updated with one click whenever the assembly changes.
I hope this helps,
Luke
Thanks for the reply.
I have tried your rule but get the following error message...
Error in rule program format:
All other Sub's or Functions must be after Sub Main()
This doesn't mean anything to me. Is it something that can be solved?
Thanks for your help
Mike
