Is there a way to get sketched symbol value which is attached to balloons
See below example, Here (2) is sketched symbol which is attached to a balloon 25. Here 2 is QTY value, Is there a way to get the sketched symbol value which is attached to a particular balloon by VBA. Any help on this will be great.
MechMachineMan
I dont understand what you are trying to do.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
I want to get some informations of the balloon (balloon no)  from the attached sketched symbol. By VBA, If a sketched symbol is attached to a balloon, I want to know the linked balloon informations.
Any help on this
