Change general styles in drawings
ThomasCassan
ThomasCassan
Hi Fans and Friends
I have just a question about chaning the general styles.
I am using a template and there are some adjustment saved in the styles.
so during a ilogic routine i want to update other drawings by my choice
current i am using this rule:
' Updaten der Stile
 Dim oIDW As DrawingDocument
    oIDW = ThisApplication.ActiveDocument
    Dim oIDWStyles As Inventor.DrawingStylesManager
    oIDWStyles = oIDW.StylesManager
    Dim i As Integer
'JW Loop durch unterstile entfernt da durch Loop unten die Aktualisierung aller Stile abgedeckt ist
    For i = 1 To oIDWStyles.Styles.Count
        'Debug.Print "Styles - " + oIDWStyles.Styles.Item(i).Name
        If oIDWStyles.Styles.Item(i).UpToDate = False Then
            oIDWStyles.Styles.Item(i).UpdateFromGlobal
        End If
    Next
    oIDW.Update
    oIDW.Save
Next
End If
but it doesnt work proper because there are still some styles in the origin mode.
whats wrong with this rule??
thx for your support!!
Thomas
bradeneuropeArthur
Hi.
Maybe for i=0 to.........
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
