LWH (Length Width an Height) from within drawing
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
We need to incorporate length, width and height in the drawing document mostly for all part, assembly and general arrangement (or erection) drawings. The following rule can be tailored to suit to achieve these objectives.
Sub Main()
oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'save text parameter "MyText" value in the string variable Value
'Dim Value As String = Parameter(oModelDoc, "Length")
'Note: this string Value could be read from any source (e.g., excel sheet).
Dim oDoc As DrawingDocument = ThisDrawing.Document
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oView As DrawingView
    'oView = oSheet.DrawingViews.Item(1)
    Dim oGeneralDimensions As GeneralDimensions
    oGeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
Dim oSSet As SelectSet = oDoc.SelectSet
100:
oYN = MessageBox.Show("DO YOU WANT TO CONTINUE? ", "ASSEMBLY SIZES", MessageBoxButtons.YesNo)
If oYN = vbYes Then
    Dim oLWT_Array As New ArrayList
    oLWT_Array.add("Length")
    oLWT_Array.add("Width")
    oLWT_Array.add("Height")
    oLWT_Array.add("Thickness")
    oLWT_Array.add("Cancel")
    oLWT_Array_IP = InputListBox("SELECT FROM ABOVE!", oLWT_Array, oLWT_Array.Item(0), "OVER ALL SIZES", "OPTIONS")
    If oLWT_Array_IP = "Cancel" Then Exit Sub
    obj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "SELECT DIMENSION FOR " & UCase(oLWT_Array_IP))
    If TypeOf obj Is GeneralDimension Then
        'reference to the selected dimension
        Dim oDim As GeneralDimension = obj
        'refrence to the DimensionText object
        Dim oDimensionText As DimensionText = oDim.Text
        oTxt_SizeOA = oDimensionText.Text
        oYN = MessageBox.Show("ASSM_" & UCase(oLWT_Array_IP) & " IS " _
        & vbLf & "" & oTxt_SizeOA _
        & vbLf & "" _
        & vbLf & "DO YOU WANT TO EDIT?", "CUSTOM iPROPERTY FOR", MessageBoxButtons.YesNo)
        If oYN = vbYes Then
        oTxt_SizeOA = InputBox("Edit if necessary: ", oLWT_Array_IP, oTxt_SizeOA)
        If oLWT_Array_IP = oLWT_Array(0) Then iProperties.Value(oModelDoc, "Custom", "ASSM_LENGTH") = oTxt_SizeOA
        If oLWT_Array_IP = oLWT_Array(1) Then iProperties.Value(oModelDoc, "Custom", "ASSM_WIDTH") = oTxt_SizeOA
        If oLWT_Array_IP = oLWT_Array(2) Then iProperties.Value(oModelDoc, "Custom", "ASSM_HEIGHT") = oTxt_SizeOA
        MessageBox.Show("Cutom iProperty: " & oLWT_Array_IP  & " - Updated!", oLWT_Array_IP)
        Goto 100:
Else If oYN = vbNo Then
'Do nothing
iLogicVb.UpdateWhenDone = True
'Beep
'ThisApplication.Documents.Open(oModelDoc_Dwg, True)
End Sub
Sub oCreate_LWH_iProperties()
'oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim oCustiProperties_Array As New ArrayList
oCustiProperties_Array.add("ASSM_LENGTH")
oCustiProperties_Array.add("ASSM_WIDTH")
oCustiProperties_Array.add("ASSM_HEIGHT")
For i = 0 To oCustiProperties_Array.Count-1
    Try
    'set property value
    oModelDoc.PropertySets.Item("Inventor User Defined Properties").Item(oCustiProperties_Array(i)).Value = CStr(i)
    Catch
    ' Assume error means not found so create it
    iProperties.Value(oModelDoc, "Custom", oCustiProperties_Array(i)) = "Test - " & CStr(i)
    'MessageBox.Show(oCustiProperties_Array(i) & ": Exists", "Title")
    End Try
Next
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Can you please explain more about requirement with examples ?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
