Change File-->Export PDF default filename to include revision iproperty?
claudio.ibarra
Message 1 of 9
claudio.ibarra
When I go to File --> Export PDF, the default filename is the drawing's filename, with .IDW replaced by .PDF. That's great, but I'd like to add the revision to the end of that.
So for 123-456.IDW at Rev 1, it defaults to 123-456 R1.pdf.
Is it possible to change the default naming behavior?
Replies (8)
Message 2 of 9
bradeneuropeArthur
So for my understanding:
You need when you press Export to Pdf inventor to display:
the 123-456.IDW at Rev 1 Export to  123-456 R1.pdf, right
Then use this method in VB.net Add in:
Private WithEvents MyFileUserInputEvents As FileUIEvents
        Private Sub MyFileUserInputEvents_OnPopulateFileMetadata(FileMetadataObjects As Inventor.ObjectsEnumerator, Formulae As String, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles MyFileUserInputEvents.OnPopulateFileMetadata
			Dim ActiveMetaData As FileMetadata
            ActiveMetaData = FileMetadataObjects.Item(1)
			oMetaData.FileName = Replace(MetaData.FileName,"." , "R" oDoc.propertyset.item(1).item("Revision Number").Value
		end sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
claudio.ibarra
I don't know how to apply this solution, but I'm willing to accept that it IS a solution.
Message 4 of 9
bradeneuropeArthur
can I assist you?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
claudio.ibarra
Yes please.
Do I enter that into the VBA Editor in the Options menu on the Tools tab?
Message 6 of 9
bradeneuropeArthur
For Vb.net?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 9
claudio.ibarra
I don't know enough to answer, I'm sorry. I don't see VB.Net in the "Add-ins" section in Tools-Options. If I'm sitting in front of vanilla Inventor Professional 2018, I don't know where to add this code.
Message 8 of 9
bradeneuropeArthur
Questions:
  • Are you familiar with coding/programming?
If not the easiest way is to create a i-logic rule that runs on document Close or another event.
Please let me know what you prefer:
  • Add-in Vb.net
  • Ilogic code
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
claudio.ibarra
I've seen iLogic code that I can re-purpose to generate a PDF with the revision in the filename, but I was wondering if it's possible to change the default filename when someone uses File--Export--PDF.
