Browser Name Part Number are not the same
andrew_canfield
Message 1 of 8
andrew_canfield
Hi.
After some content center editing the part number does not match the description in the browser.
I can manually open, double click, delete the description & then refresh & all is well, the new part number is displayed in the browser.
Is there a way to do this by code?
Only a few thousand cc parts to go through.
Replies (7)
Message 2 of 8
Rob67ert
In the Content Center Editor you can Map to a Inventor Property.
If you would like to have the File name in the browser, you should map the File Name Column to Project.Description
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 8
andrew_canfield
Thanks Robert
It's working ok on new parts.
It's editing existing parts where the issue occurs - sorry, should of mentioned that.
Andrew
Message 4 of 8
Rob67ert
Open the assembly where the error is in.
Then use Refresh from the Content Center toolbar under Manage.
Robert
Message 5 of 8
andrew_canfield
Thanks again.
I have tried that - the lower screen shot shows the BOM information is upto date.
The Part number information in the browser does not match the BOM.
This is the issue.
I've seen it before, think it's a known issue, just wondering if work around is possible.
Andrew
Message 6 of 8
andrew_canfield
Hopefully this helps:
Message 7 of 8
MechMachineMan
Using Productivity Tools > Rename Browser Nodes doesn't work?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 8
andrew_canfield
Easy when you know how!
Thanks - maybe need to move this thread to the normal discussion group.
Andrew
