Move occurrences with same filename
(inventor 2017.4)
I use iLogic to go through all ReferencedDocuments in an assembly. I search for specific iProperties to get the filenames of files that match my criteria.
Can someone please help me set the moveOcc ComponentOccurrence with the help of my filename and not the occurrence name. I assume the problem is that one filename can be several difference occurrences. (se below snippet of my code)
So what in summary what i would like to do: Move all occurrences with a specific filename to a specific coordinate and ground it/them
Dim moveOcc As ComponentOccurrence = Component.InventorComponent("myoccurrence:1")
Dim oTransform As Matrix = moveOcc.Transformation
oTransform.SetTranslation(ThisApplication.TransientGeometry.CreateVector(stay4*convFactor, 0*convFactor, 0*convFactor))
moveOcc.Transformation = oTransform
moveOcc.Grounded = True
Any input would really be appreciated
MechMachineMan
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-0C5859C6-83AB-4F62-A92B-73B419DFE96C
oFileNameToMove = "C:\Test.ipt"
oDocToMove = ThisApplication.Documents.Open(oFileNameToMove, True)
For Each oOcc As Occurrence in oParentAsm.AllReferencedOccurrences(oDocToMove)
    'Do your stuff
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for your reply,
I didn't manage to use the code you supplied (my bad, i really need to learn ilogic form the beginning instead of copy paste until it works)
i used
SyntaxEditor Code Snippet
        For Each oOccurrence In asmDef.Occurrences
            If iProperties.Value(oOccurrence.Name, "Summary", "Title") = "Jib Stay Brackets" Then
                moveOccName = oOccurrence.Name 'Set the occurrence name to move
        Next
Since this time i only needed to move one occurrence it works okay.
