BOM sorting and Renumbering in Assy
Hi
I have a custom itemnumber and qty ilogic code I use to get unique properties on each dwg.
The code runs from the main assy level in the 3D enviroment.
I would love to get the code to sort BOM by part number and then renumber items before doing what it already does.
I've seen it done very nicely from a drawing with iLogic, but I need it done directly from the 3D assy.
Any ideas?
MechMachineMan
Look at this file:
"C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm"
Type in 'Application' in the search tab.
Select Application object. Understand that when you start a call with ThisApplication, this is the object that is returned.
Select a logical path to what you are looking for under the properties/methods of the Application Object (what is now viewable in the main screen).
ie ActiveDocument property.
(Our code would now read Dim oDoc As Document = ThisApplication.ActiveDocument)
Keep following through, and eventually you wind up at:
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
oCompDef= oDoc.ComponentDefinition
Try
Dim oBOM As BOM = oCompDef.BOM
oBOM = oCompDef.BOM
Catch
With oBOM
       .Sort() 'PLUS ARGUMENTS OF METHOD
       .Renumber 'PLUS ARGUMENTS OF METHOD
End With
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rhasell
Hi
I wrote some code to do exactly that.
I manged to get it to work 95% of the time, but it was unreliable. It would never sort the same way from one iteration to the next.
I found that making a GA drawing, and doing my sorts from a dummy GA drawing works 100% of the time.
Attached is a copy of my working code, it's old and have not looked at it for years, hopefully you can get something out of it.
Dim oDoc As AssemblyDocument
' Set a reference to the BOM
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Make sure that the parts only view is enabled.
    oBOM.PartsOnlyViewEnabled = True
' Set a reference to the "Parts Only" BOMView
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Parts Only")
Call oBOMView.Sort("BOM Structure",True ,"TYPE",True ,"Stock Number",True)
Call oBOMView.Renumber(1, 1)
MessageBox.Show("Done", "Sort BOM")
Reg
2026.1
