add in button only large buttons
klaaspietmeulen
klaaspietmeulen
Hello
ik wrhite my first add-in for inventor 2015 and this is works fine
i used the 'inventor .NET Addin Pro' wizzard
ik have a custom button in my ribbon this is a large button 32x32
no i want to make a small button 16x16
but than the buttun shows not the right piture
how do i make this possible
Klaas
Vladimir.Ananyev
From the API perspective the ControlDefinitions.AddButtonDefinition method is responsible for the icons associated with the button definition. Here is this method syntax:
ControlDefinitions.AddButtonDefinition( DisplayName As String, InternalName As String, Classification As CommandTypesEnum, [ClientId] As Variant, [DescriptionText] As String, [ToolTipText] As String, [StandardIcon] As Variant, [LargeIcon] As Variant, [ButtonDisplay] As ButtonDisplayEnum ) As ButtonDefinition
Ideally you should provide both standard (16x16) and large (32x32) icons as input IPictureDisp objects.  So your code could be similar to the following fragment:
Dim oCtrlDefs As ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions
mButtonDef = oCtrlDefs.AddButtonDefinition( _
		"Custom Cmd", _
		"Company:AddInName:Button1", _
		CommandTypesEnum.kQueryOnlyCmdType, _
		"AddInGuid", _
		"Description", _
		"Tolltip text", _
		StandardIcon_16x16, _
		LargeIcon_32x32, _
		ButtonDisplayEnum.kDisplayTextInLearningMode)
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
klaaspietmeulen
Hello
this  is my code now
Imports System.Windows.Forms
Imports System.Drawing
Imports Inventor
Namespace PolemPrintManager
''' <summary>
''' The class wrapps up Inventor Button creation stuffs and is easy to use.
''' No need to derive. Create an instance using either constructor and assign the Action.
''' </summary>
Public Class InventorButton
#Region "Fields & Properties"
Private mButtonDef As ButtonDefinition
Public Property ButtonDef() As ButtonDefinition
Get
Return mButtonDef
End Get
Set(value As ButtonDefinition)
mButtonDef = value
End Set
End Property
#End Region
#Region "Constructors"
''' <summary>
''' The most comprehensive signature.
''' </summary>
Public Sub New(displayName As String, internalName As String, description As String, tooltip As String, standardIcon As Icon, largeIcon As Icon, _
commandType As CommandTypesEnum, buttonDisplayType As ButtonDisplayEnum)
Create(displayName, internalName, description, tooltip, AddinGlobal.ClassId, standardIcon, _
largeIcon, commandType, buttonDisplayType)
End Sub
''' <summary>
''' The signature does not care about Command Type (always editing) and Button Display (always with text).
''' </summary>
Public Sub New(displayName As String, internalName As String, description As String, tooltip As String, standardIcon As Icon, largeIcon As Icon)
Create(displayName, internalName, description, tooltip, AddinGlobal.ClassId, Nothing, _
Nothing, CommandTypesEnum.kEditMaskCmdType, ButtonDisplayEnum.kAlwaysDisplayText)
End Sub
''' <summary>
''' The signature does not care about icons.
''' </summary>
Public Sub New(displayName As String, internalName As String, description As String, tooltip As String, commandType As CommandTypesEnum, buttonDisplayType As ButtonDisplayEnum)
Nothing, commandType, buttonDisplayType)
End Sub
''' <summary>
''' This signature only cares about display name and icons.
''' </summary>
''' <param name="displayName"></param>
''' <param name="standardIcon"></param>
''' <param name="largeIcon"></param>
Public Sub New(displayName As String, standardIcon As Icon, largeIcon As Icon)
Create(displayName, displayName, displayName, displayName, AddinGlobal.ClassId, standardIcon, _
largeIcon, CommandTypesEnum.kEditMaskCmdType, ButtonDisplayEnum.kAlwaysDisplayText)
End Sub
''' <summary>
''' The simplest signature, which can be good for prototyping.
''' </summary>
Public Sub New(displayName As String)
Create(displayName, displayName, displayName, displayName, AddinGlobal.ClassId, Nothing, _
End Sub
''' <summary>
''' The helper method for constructors to call to avoid duplicate code.
''' </summary>
Public Sub Create(displayName As String, internalName As String, description As String, tooltip As String, clientId As String, standardIcon As Icon, _
largeIcon As Icon, commandType As CommandTypesEnum, buttonDisplayType As ButtonDisplayEnum)
If String.IsNullOrEmpty(clientId) Then
clientId = AddinGlobal.ClassId
Dim standardIconIPictureDisp As stdole.IPictureDisp = Nothing
Dim largeIconIPictureDisp As stdole.IPictureDisp = Nothing
If standardIcon IsNot Nothing Then
standardIconIPictureDisp = IconToPicture(standardIcon)
largeIconIPictureDisp = IconToPicture(largeIcon)
mButtonDef = AddinGlobal.InventorApp.CommandManager.ControlDefinitions.AddButtonDefinition(displayName, internalName, commandType, clientId, description, tooltip, _
standardIconIPictureDisp, largeIconIPictureDisp, buttonDisplayType)
mButtonDef.Enabled = True
AddHandler mButtonDef.OnExecute, AddressOf ButtonDefinition_OnExecute
DisplayText = True
AddinGlobal.ButtonList.Add(Me)
End Sub
#End Region
#Region "Behavior"
Public Property DisplayBigIcon() As Boolean
Get
Return m_DisplayBigIcon
End Get
Set(value As Boolean)
m_DisplayBigIcon = value
End Set
End Property
Private m_DisplayBigIcon As Boolean
Public Property DisplayText() As Boolean
Get
Return m_DisplayText
End Get
m_DisplayText = value
End Set
End Property
Private m_DisplayText As Boolean
Public Property InsertBeforeTarget() As Boolean
Get
Return m_InsertBeforeTarget
End Get
m_InsertBeforeTarget = value
End Set
End Property
Private m_InsertBeforeTarget As Boolean
Public Sub SetBehavior(displayBigIcon__1 As Boolean, displayText__2 As Boolean, insertBeforeTarget__3 As Boolean)
DisplayBigIcon = displayBigIcon__1
DisplayText = displayText__2
InsertBeforeTarget = insertBeforeTarget__3
End Sub
Public Sub CopyBehaviorFrom(button As InventorButton)
Me.DisplayBigIcon = button.DisplayBigIcon
Me.DisplayText = button.DisplayText
Me.InsertBeforeTarget = Me.InsertBeforeTarget
End Sub
#End Region
#Region "Actions"
''' <summary>
''' The button callback method.
''' </summary>
''' <param name="context"></param>
Private Sub ButtonDefinition_OnExecute(context As NameValueMap)
If Execute IsNot Nothing Then
Execute()
Else
MessageBox.Show("Nothing to execute.")
End Sub
''' <summary>
''' The button action to be assigned from anywhere outside.
''' </summary>
Public Execute As Action
#End Region
#Region "Image Converters"
Public Shared Function ImageToPicture(image As Image) As stdole.IPictureDisp
Return ImageConverter.ImageToPicture(image)
End Function
Public Shared Function IconToPicture(icon As Icon) As stdole.IPictureDisp
Return ImageConverter.ImageToPicture(icon.ToBitmap())
End Function
Public Shared Function PictureToImage(picture As stdole.IPictureDisp) As Image
Return ImageConverter.PictureToImage(picture)
End Function
Public Shared Function PictureToIcon(picture As stdole.IPictureDisp) As Icon
Return ImageConverter.PictureToIcon(picture)
End Function
Private Class ImageConverter
Inherits AxHost
Public Sub New()
MyBase.New(String.Empty)
End Sub
Return DirectCast(GetIPictureDispFromPicture(image), stdole.IPictureDisp)
End Function
Return ImageToPicture(icon.ToBitmap())
End Function
Return GetPictureFromIPicture(picture)
End Function
Dim bitmap As New Bitmap(PictureToImage(picture))
Return System.Drawing.Icon.FromHandle(bitmap.GetHicon())
End Function
End Class
#End Region
End Class
End Namespace
Vladimir.Ananyev
Could you check if StandardIcon argument is not Nothing when you call Create method?
Vladimir Ananyev
