BOM set Reference
BOM set Reference
jostroopers
Message 1 of 9
BOM set Reference
jostroopers
I have an assembly in which I have created 3 LOD, 1_Ruit, 2_Ruit, 3_Ruit.
With a text parameter 'Deling' and an iLogic code 'LOD' I can send the LOD so that components are suppressed.
However, if I look at the BOM, the suppressed parts are not set to Reference so that they are still counted in the BOM.
How do I use iLogic to set the suppressed components to Reference in the BOM?
I have tried several codes but am not an expert.
If Deling = "1_Ruit" Then
oOcc.BOMStructure "Tussenligger" = Reference
oOcc.BOMStructure "Tussenruit" = Reference
And so on.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Replies (8)
Message 2 of 9
MechMachineMan
Resource utilization is key to successful programming:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-F298DB7C-AB42-4AA9-B3F4-980A8BF78A01
All 3 below work (in their various cases). The best one for readability is the middle. The best one for performance (and avoiding issues) is the the bottom.
oOcc.BOMStructure = kReferenceBOMStructure
OR
oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
OR
oOcc.BOMStructure = 51972
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
jostroopers
Do i use that in this way?
oOcc.BOMStructure "Tussenruit" = 51972
Mvg Jos
Message 4 of 9
bradeneuropeArthur
Yes you do already.
The 51972 is the bottom one...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 9
MechMachineMan
No... you use it exactly as I typed it in:
Justin K
Message 6 of 9
clutsa
You're close. I think you're trying to do something more like
myPart = Component.InventorComponent("Tussenruit")
myPart.BOMStructure = 51972 'Reference
myPart.BOMStructure = 51969 'Default? I think
Also you could do a loop at the end like
Dim doc As AssemblyDocument
doc = ThisDoc.Document
For Each oOcc In doc.ComponentDefinition.Occurrences
	If oOcc.Suppressed Then
		oOcc.BOMStructure = 51972 'reference
	Else
		oOcc.BOMStructure = 51969 'default
Next
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 7 of 9
jostroopers
@MechMachineMan
How dus the code know that "Tussenruit" has to go Reference.
Mvg Jos
Message 8 of 9
MechMachineMan
The way I wrote it already implies that you have the occurrence you want assigned to the variable 'oOcc'.
@clutsa mentioned what you need to do to grab the occurrence in his post.
Justin K
Message 9 of 9
clutsa
Sorry that's what I was trying to clarify for you.
oOcc = Component.InventorComponent("Tussenruit")
Else
and if you don't want to declare each part that needs to be set to reference you could do the loop to set all parts that is suppressed to a referenced BOM.
	Else
Next
