Hi Autodesk Community,
First off I want to say how helpful it has been to pose questions here and search the database of questions that others have posted! It's awesome to see everyone involved in helping each other out.
I'm looking for some iLogic Code that will allow me to batch export IDW's to PDF's. I've tried using Task Scheduler but unfortunately that only has the Print to PDF option. We work in a non-vaulted system with many project files (IPJ's). I would like to see if it is possible to get some iLogic code (rule or form is fine) that can be launched from a "top level" assembly (IAM) which allows the user to manually batch select sub-folders that exist under the active IPJ structure. The function would locate the IDW's in each sub-folder and output them as See example below.
Thanks in advance and Happy Holidays!
