Batch Export To PDF Code
amarinXG8V6
Message 1 of 16
amarinXG8V6
Hi Autodesk Community,
First off I want to say how helpful it has been to pose questions here and search the database of questions that others have posted! It's awesome to see everyone involved in helping each other out.
I'm looking for some iLogic Code that will allow me to batch export IDW's to PDF's. I've tried using Task Scheduler but unfortunately that only has the Print to PDF option. We work in a non-vaulted system with many project files (IPJ's). I would like to see if it is possible to get some iLogic code (rule or form is fine) that can be launched from a "top level" assembly (IAM) which allows the user to manually batch select sub-folders that exist under the active IPJ structure. The function would locate the IDW's in each sub-folder and output them as See example below.
Thanks in advance and Happy Holidays!
Replies (15)
Message 2 of 16
bradeneuropeArthur
Means like:
For Each idw in folder and subfolder
Print pdf
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 16
amarinXG8V6
@bradeneuropeArthur ,
Yes, that is correct. For each IDW in the selected sub-folder, export to PDF.
Thank you,
Alex
Message 4 of 16
bradeneuropeArthur
I can make quickly an addin for you in vb.net. are you happy with that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 16
amarinXG8V6
That would be amazing! Best Christmas present thus far. It would save me time and headache!
Thank you,
Alex Marin-Serghie
Message 6 of 16
bradeneuropeArthur
Could you have a test.
Place the unzipped folder in "C:\Users\UserName\AppData\Roaming\Autodesk\ApplicationPlugins"
if loaded you will find this button in the assembly Tools Tab.
The export folder (where the Pdf is saved) is: C:\TEMP
Hope that this is what you need in principle.
We can make adjustments of course.
If you have questions please send me a message.
Arthur Knoors
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 16
amarinXG8V6
Hi Arthur,
Thank you for taking the time to do this. Unfortunately I can't seem to extract the files from the zipped folder. This is the error message I get when I try to "Extract All" using the typical Windows function. Do you have any suggestions on how I can get the .dll and .addin files out of the zipped folder?
Thank you,
Alex Marin-Serghie
Message 8 of 16
amarinXG8V6
@bradeneuropeArthur
Hi Arthur,
I also tried using 7-Zip to extract the files but it looks like the folder may be password protected. Could you provide the password please?
Thank you,
Alex Marin-Serghie
Message 9 of 16
bradeneuropeArthur
Just send you a PM.
Arthur Knoors
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 16
amarinXG8V6
Thank you! I just responded to the PM.
Message 11 of 16
bradeneuropeArthur
As promised an update of the add-in.
If you have question please send me a message.
Regards
Arthur Knoors
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 16
amarinXG8V6
Thank you sir! I haven't had a chance to try this out but will give it a go this afternoon. I appreciate you creating the code and updating it for me.
Have a good day,
Alex
Message 13 of 16
bradeneuropeArthur
Appreciate you appraisal!
Let me know if I can help you again in future.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 16
Yogesh_SapkaleFNFVA
I  am unable to extract this zip file as it is password protected, could you please provide password of file to extract this.
Yogesh
Message 15 of 16
bradeneuropeArthur
Please send me a private message with you request.
Thanks.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 16
Yogesh_SapkaleFNFVA
Thank you! I just responded my request in PM.
Yogesh Sapkale
