Automated offset planes
NRHartness
NRHartness
     I would like to be able to place a model in inventor and have a tool that automatically creates offset planes on every flat area with a default offset of zero. I was thinking that creating an add in would be best. Does anyone have any advice or code related to how I could achieve this? Any help is greatly appreciated.
Nathan
bradeneuropeArthur
I indeed prefer creating a add-in.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
NRHartness
Do you have any advice on how this add in would work? How could I use the API to automatically see faces and create these planes?
bradeneuropeArthur
Could you share an example
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
This will do the trick with i-logic:
Dim a As PartDocument = ThisDoc.Document
Dim b As PartComponentDefinition = a.ComponentDefinition
Dim c As SurfaceBody = b.SurfaceBodies.Item(1)
Dim wpl As  WorkPlane
Dim f As Face
For Each f In c.Faces
	If f.SurfaceType = 5890 Then
		Try
		wpl = b.WorkPlanes.AddByPlaneAndOffset(f,0)
		Catch
		End Try
	End If
	Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
