Auto constrain in current position with Origin Planes flush or mate
SevInventor
Message 1 of 25
SevInventor
I’ve created or copy pasted  this Ilogic rule . It measures the distance of the origin planes of each occurrence to the origin planes of the active assembly. Then it creates a constraint of these two planes with the measured value.
With this rule we want to change existing assemblies to avoid sick constraints after model changes somewhere in the assembly structure  and maybe have a better performance (not yet tested) of big assemblies after every Occurrence has only 3 Constrains to the Origin Plane.
Most of the Occurrences in our assemblies have somehow parallel origin planes to the top level origin planes.
So the rule works but its quite slow.
Questions:
How can I make the decision if the constraint has to be flush/ mate and posive/negative value for the constraints quicker. Now the codes creates each constraint  flush, mate, positive, negative and deletes if the constraint is sick.-->this is only a bad workaround I think. I have tried something with Eulerian angles to get the orientation of the occurrence but I don’t know yet how this angle can make the decision flush/ mate and posive/negative value?
How can I create  constraints of Occurrences with unequal 90° to the origin? Without angle constraints.
Deleting the existing Constraints is very brutal. How could I make this more smart. Maybe a new LOD with the new Constraints and the old ones just suppressed.
Maybe somebody has use of my code
Sub Main
Dim oAsm As AssemblyDocument= ThisApplication.ActiveDocument
On Error Resume Next
'get the active assembly
Dim oAsmComp As AssemblyComponentDefinition= ThisApplication.ActiveDocument.ComponentDefinition
For Each oConstraint In oAsmComp.Constraints
oConstraint.Delete
Next
'set the Master LOD active
Dim oLODRep As LevelOfDetailRepresentation
oLODRep = oAsmComp.RepresentationsManager.LevelOfDetailRepresentations.Item("Master")
oLODRep.Activate
'Iterate through all of the top level occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmComp.Occurrences
'Try
'	'ground everything in the top level
	oOccurrence.Grounded = True
'Catch
'	end try
Next
	Dim oUM As UnitsOfMeasure = oAsm.UnitsOfMeasure
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oAsm.ComponentDefinition.Occurrences
	'Create a proxy for Face0 (The face in the context of the assembly)
Dim Zähler As Integer = 1
'cycle each Origin plane in the top assembly
For Zähler = 1 To 3
Dim curAsmorPlane As WorkPlane = oAsmComp.WorkPlanes.Item(Zähler)
'Dim oComp1 As ComponentOccurrence = oADef.Occurrences.Item(1)
Dim oCompAsmDef As AssemblyComponentDefinition
Dim oCompPtDef As PartComponentDefinition
'cycle each Origin plane in the first level Occurence in the assembly
For Zähler2 = 1 To 3
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oCompAsmDef = oOcc.Definition
	oOcc.CreateGeometryProxy(oCompAsmDef.WorkPlanes.Item(Zähler2),curCompOriPlane)
ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oCompPtDef = oOcc.Definition
	oOcc.CreateGeometryProxy(oCompPtDef.WorkPlanes.Item(Zähler2),curCompOriPlane)
End If
	'Measure distance
	Dim oNV As NameValueMap
'	Dim Distance As Double
'	Try
'Dim angle As Double = ThisApplication.MeasureTools.
	Dim angle As Double = ThisApplication.MeasureTools.GetAngle(curAsmorPlane, curCompOriPlane)
	'Angle in deg
'	MsgBox(angle)
	angle = (angle * 180) / PI
	If angle=0 Then
				'Convert distance from database units to default units of the document
				Dim Distance1 As Double = ThisApplication.MeasureTools.GetMinimumDistance(curAsmorPlane, curCompOriPlane)
				Dim oConstraint As AssemblyConstraint
				Distance = oUM.ConvertUnits(Distance1, UnitsTypeEnum.kDatabaseLengthUnits, oUM.LengthUnits)
				'Return the value in a messagebox just to control that it's right
				Distance= Round(Distance,3)
'				MsgBox(Distance)
				oConstraint=oAsmComp.Constraints.AddMateConstraint(curAsmorPlane, curCompOriPlane, Distance1)
		      If oConstraint.HealthStatus = oConstraint.HealthStatus.kInconsistentHealth Then
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddMateConstraint(curAsmorPlane, curCompOriPlane, -Distance1)
			  End If
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddFlushConstraint(curAsmorPlane, curCompOriPlane, Distance1)
			  End If
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddFlushConstraint(curAsmorPlane, curCompOriPlane, -Distance1)
			  End If
	          oConstraint.Delete
			  End If
	  End If
'	Catch
'	End Try
	Next
Next
'Try
	oOcc.Grounded = False
'	Catch
'		End try
Next
End Sub
second code for the Occurence eulerian angle adapted from her:
https://adndevblog.typepad.com/manufacturing/2013/01/inventor-eulerian-angles-of-assembly-component....
Sub Main()
    Dim oDoc As AssemblyDocument
     oDoc = ThisApplication.ActiveDocument
     	oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a oOcc plate")
    Dim oMat As Matrix
     oMat = oOcc.Transformation
    Dim aRotAngles(2) As Double
    Call CalculateRotationAngles(oMat, aRotAngles)
    ' Print results
'    Dim i As Integer
'    For i = 0 To 2
      msgbox(aRotAngles(0)  & vbCrLf & aRotAngles(1) & vbCrLf & aRotAngles(2))
'    Next i
    Beep
End Sub
Sub CalculateRotationAngles(ByVal oMatrix As Inventor.Matrix,ByRef aRotAngles() As Double)
    Const PI = 3.14159265358979
    Const TODEGREES As Double = 180 / PI
    Dim dB As Double
    Dim dC As Double
    Dim dNumer As Double
    Dim dDenom As Double
    Dim dAcosValue As Double
    Dim oRotate As Inventor.Matrix
    Dim oAxis As Inventor.Vector
    Dim oCenter As Inventor.Point
     oRotate = ThisApplication.TransientGeometry.CreateMatrix
     oAxis = ThisApplication.TransientGeometry.CreateVector
     oCenter = ThisApplication.TransientGeometry.CreatePoint
    oCenter.X = 0
    oCenter.Y = 0
    oCenter.Z = 0
    ' Choose aRotAngles[0] about x which transforms axes[2] onto the x-z plane
    dB = oMatrix.Cell(2, 3)
    dC = oMatrix.Cell(3, 3)
    dNumer = dC
    dDenom = Sqrt(dB * dB + dC * dC)
    ' Make sure we can do the division.  If not, then axes[2] is already in the x-z plane
    If (Abs(dDenom) <= 0.000001) Then
        aRotAngles(0) = 0#
    Else
        If (dNumer / dDenom >= 1#) Then
            dAcosValue = 0#
        Else
            If (dNumer / dDenom <= -1#) Then
                dAcosValue = PI
            Else
                dAcosValue = Acos(dNumer / dDenom)
            End If
        End If
        aRotAngles(0) = Sign(dB) * dAcosValue
        oAxis.X = 1
        oAxis.Y = 0
        oAxis.Z = 0
        Call oRotate.SetToRotation(aRotAngles(0), oAxis, oCenter)
        Call oMatrix.PreMultiplyBy(oRotate)
    End If
    ' Choose aRotAngles[1] about y which transforms axes[3] onto the z axis
    If (oMatrix.Cell(3, 3) >= 1#) Then
        dAcosValue = 0#
    Else
        If (oMatrix.Cell(3, 3) <= -1#) Then
            dAcosValue = PI
        Else
            dAcosValue = Acos(oMatrix.Cell(3, 3))
        End If
    End If
    aRotAngles(1) = Math.Sign(-oMatrix.Cell(1, 3)) * dAcosValue
    oAxis.X = 0
    oAxis.Y = 1
    oAxis.Z = 0
    Call oRotate.SetToRotation(aRotAngles(1), oAxis, oCenter)
    ' Choose aRotAngles[2] about z which transforms axes[0] onto the x axis
    If (oMatrix.Cell(1, 1) >= 1#) Then
        dAcosValue = 0#
    Else
        If (oMatrix.Cell(1, 1) <= -1#) Then
            dAcosValue = PI
        Else
            dAcosValue = Acos(oMatrix.Cell(1, 1))
        End If
    End If
    aRotAngles(2) = Math.Sign(-oMatrix.Cell(2, 1)) * dAcosValue
    'if you want to get the result in degrees
    aRotAngles(0) = Round(aRotAngles(0) * TODEGREES,4)
    aRotAngles(1) = Round(aRotAngles(1) * TODEGREES,4)
    aRotAngles(2) = Round(aRotAngles(2) * TODEGREES,4)
End Sub
Public Function Acos(value) As Double
    Acos = Math.Atan(-value / Math.Sqrt(-value * value + 1)) + 2 * Math.Atan(1)
End Function
Replies (24)
Message 21 of 25
Rich-T
This is excellent, many thanks
Message 22 of 25
Rich-T
As another variation to this rule, can we constraint all parts to the active assembly's origin work planes - instead of selecting a base component ?
Or perhaps do this as a selection option for the 'base part' which allows the current assembly doc to be selected ?
Message 23 of 25
SevInventor
@Rich-T
Yes, my Code from 03-11-2022 07:23 AM is with Origin planes of the assembly instead of base component
Message 24 of 25
Rich-T
oh yes, thank you.
Message 25 of 25
andreas.jonssonF98YC
I could not get any of the scripts to work properly. I would like to run the code. pick the master and then pick the modell i would like to constrain.
then it shall measure the distance between them and add a constraint. I have tried to modify the codes but with no luck,
