Addins - Using the Inventor Themes Light / Dark
NachoShaw
Advisor Advisor
NachoShaw
Hi
Getting addins to adopt the light / dark themes to some has been a challenge. I went through an arduous task of creating a skin based on the dark theme and i had to fill in a lot of blanks. Then the other day i was looking for a library in the Inventor 2024/Bin folder and came across this-
Autodesk.iLogic.ThemeSkins
A quick reference add and look inside and found the themes were under a DevExpress skin manager. I have a DevExpress subscription so i set up a skin class to pull out the theme and applied it to my custom addin form. Worked like a charm so here is the code for anyone who wants to do the same. a DevExpress subscription is required (unless i make a special library as a tool i guess).
you need references to the following
using DevExpress.LookAndFeel;
using DevExpress.Skins;
using DevExpress.UserSkins;
using DevExpress.Utils;
using DevExpress.XtraEditors;
using Autodesk.iLogic.ThemeSkins;
using DevExpress.Skins.Info;
using System.Reflection;
using Inventor;
This code gets the theme skin and registers it, then checks what theme style you currently have in Inventor and switches the theme to the inventor theme
public YourClassName()
    // This call is required by the designer.
    InitializeComponent();
    string DarkTheme = "inventor dark theme";
    string LightTheme = "inventor light theme";
    string AdeskLib = "Autodesk.iLogic.ThemeSkins.CustomSkins.";
    SkinManager.EnableFormSkins();
    var valDark = new SkinBlobXmlCreator(DarkTheme, AdeskLib, typeof(CustomThemeSkins).Assembly, null as string);
    var valLight = new SkinBlobXmlCreator(LightTheme, AdeskLib, typeof(CustomThemeSkins).Assembly, null as string);
    SkinManager.Default.RegisterSkin(valDark);
    SkinManager.Default.RegisterSkin(valLight);
    Inventor.ThemeManager oThemeManager = AddinGlobal.InventorApp.ThemeManager;
    Inventor.Theme oTheme = oThemeManager.ActiveTheme;
    switch (oTheme.Name)
        case "LightTheme":
            this.LookAndFeel.SetSkinStyle(LightTheme);
            break;
        case "DarkTheme":
            this.LookAndFeel.SetSkinStyle(DarkTheme);
            break;
    LookAndFeel.UpdateStyleSettings();
And also in dotnet
Imports DevExpress.LookAndFeel
Imports DevExpress.Skins
Imports DevExpress.UserSkins
Imports DevExpress.Utils
Imports DevExpress.XtraEditors
Imports Autodesk.iLogic.ThemeSkins
Imports DevExpress.Skins.Info
Imports System.Reflection
Imports Inventor
Public Sub New()
    ' This call is required by the designer.
    Dim DarkTheme As String = "inventor dark theme"
    Dim LightTheme As String = "inventor light theme"
    Dim AdeskLib As String = "Autodesk.iLogic.ThemeSkins.CustomSkins."
    Dim valDark As New SkinBlobXmlCreator(DarkTheme, AdeskLib, GetType(CustomThemeSkins).Assembly, DirectCast(Nothing, String))
    Dim valLight As New SkinBlobXmlCreator(LightTheme, AdeskLib, GetType(CustomThemeSkins).Assembly, DirectCast(Nothing, String))
    Dim oThemeManager As Inventor.ThemeManager = AddinGlobal.InventorApp.ThemeManager
    Dim oTheme As Inventor.Theme = oThemeManager.ActiveTheme
    Select Case oTheme.Name
        Case "LightTheme"
            Me.LookAndFeel.SetSkinStyle(LightTheme)
        Case "DarkTheme"
            Me.LookAndFeel.SetSkinStyle(DarkTheme)
    End Select
End Sub
Hope that helps
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
jjstr8
I don't have DevExpress, so I tried the brute-force method. I gave up (for the time being) on making all my windows support light/dark mode. I ended up just supporting it in simple dockable windows, since a mismatch sticks out pretty bad. I added an event that any of them can subscribe to to listen for a theme change. I also tweaked my icons to work for both themes, but it's easy enough to swap them on a theme change.
Mustafa.Salaheldin
Thanks @NachoShaw I figured this out too. The point that I still investigating is how to apply the Inventor default theme to my custom DevExpress UserControl. I don't want to use the iLogic Theme, I want to use Inventor Theme.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
NShawAcacia
Community Visitor
Community Visitor
Hi
I included a vb.net version that works direct in Visual Studio on a project solution. Happy to help you get there if you need bud, just give me a bit of what you're trying to do. connect privately if you need
Mustafa.Salaheldin
@NShawAcacia Thanks, but again, your code applied the iLogic skins, not the Inventor skin, and by the way there is a direct call to the theme register then skin apply, rather than re-implementing the CustomThemeSkins class.
¯\_(ツ)_/¯
Mustafa Salaheldin
