Update All Model States of ipt.
I'm making a part that has hundreds of model states. I edit it via spreadsheet to make tens and hundreds of model states at once, save the spreadsheet and close it out, let the inventor part load the new model states, but then it shows I need to manually activate and local update every single model state. That's going to take forever.
I've presented this issue before and was given these codes. They are no longer working (not sure if it's cause of a basic update or if it's cause I'm on 2026 instead of 2025
Code 1:
Dim oDoc As Inventor.Document = ThisDoc.FactoryDocument If oDoc Is Nothing Then Return Dim oMSs As ModelStates = oDoc.ComponentDefinition.ModelStates If oMSs Is Nothing OrElse oMSs.Count = 0 Then Return Dim oAMS As ModelState = oMSs.ActiveModelState For Each oMS As ModelState In oMSs oMS.Activate Dim oMSDoc As Inventor.Document = TryCast(oMS.Document, Inventor.Document) If oMSDoc Is Nothing Then Continue For oMSDoc.Update2(True) Next oMS If oMSs.ActiveModelState IsNot oAMS Then oAMS.Activate
Code 2:
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument If oDoc Is Nothing Then Return If (Not TypeOf oDoc Is AssemblyDocument) AndAlso (Not TypeOf oDoc Is PartDocument) Then Return If oDoc.ComponentDefinition.IsModelStateMember Then oDoc = oDoc.ComponentDefinition.FactoryDocument End If Dim oMSs As ModelStates = oDoc.ComponentDefinition.ModelStates If (oMSs Is Nothing) OrElse (oMSs.Count < 2) Then Return Dim oAMS As ModelState = oMSs.ActiveModelState For Each oMS As ModelState In oMSs oMS.Activate() Dim oFDoc As Inventor.Document = ThisApplication.ActiveDocument oFDoc.Update2(True) Next oMS If oMSs.ActiveModelState IsNot oAMS Then oAMS.Activate()
I've tried running those rules, rebuilding all, and updating mass. All with scope as single member, scope as all members. I don't know if 'Global Update' would work, but it's greyed out so I can't even try it.
I need help finding either a command that will update all model states or if there's some sort of rule I can write and run to go through and update each model state.
