Auto constrain in current position with Origin Planes flush or mate
SevInventor
Message 1 of 26
SevInventor
I’ve created or copy pasted  this Ilogic rule . It measures the distance of the origin planes of each occurrence to the origin planes of the active assembly. Then it creates a constraint of these two planes with the measured value.
With this rule we want to change existing assemblies to avoid sick constraints after model changes somewhere in the assembly structure  and maybe have a better performance (not yet tested) of big assemblies after every Occurrence has only 3 Constrains to the Origin Plane.
Most of the Occurrences in our assemblies have somehow parallel origin planes to the top level origin planes.
So the rule works but its quite slow.
Questions:
How can I make the decision if the constraint has to be flush/ mate and posive/negative value for the constraints quicker. Now the codes creates each constraint  flush, mate, positive, negative and deletes if the constraint is sick.-->this is only a bad workaround I think. I have tried something with Eulerian angles to get the orientation of the occurrence but I don’t know yet how this angle can make the decision flush/ mate and posive/negative value?
How can I create  constraints of Occurrences with unequal 90° to the origin? Without angle constraints.
Deleting the existing Constraints is very brutal. How could I make this more smart. Maybe a new LOD with the new Constraints and the old ones just suppressed.
Maybe somebody has use of my code
Sub Main
Dim oAsm As AssemblyDocument= ThisApplication.ActiveDocument
On Error Resume Next
'get the active assembly
Dim oAsmComp As AssemblyComponentDefinition= ThisApplication.ActiveDocument.ComponentDefinition
For Each oConstraint In oAsmComp.Constraints
oConstraint.Delete
Next
'set the Master LOD active
Dim oLODRep As LevelOfDetailRepresentation
oLODRep = oAsmComp.RepresentationsManager.LevelOfDetailRepresentations.Item("Master")
oLODRep.Activate
'Iterate through all of the top level occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmComp.Occurrences
'Try
'	'ground everything in the top level
	oOccurrence.Grounded = True
'Catch
'	end try
Next
	Dim oUM As UnitsOfMeasure = oAsm.UnitsOfMeasure
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oAsm.ComponentDefinition.Occurrences
	'Create a proxy for Face0 (The face in the context of the assembly)
Dim Zähler As Integer = 1
'cycle each Origin plane in the top assembly
For Zähler = 1 To 3
Dim curAsmorPlane As WorkPlane = oAsmComp.WorkPlanes.Item(Zähler)
'Dim oComp1 As ComponentOccurrence = oADef.Occurrences.Item(1)
Dim oCompAsmDef As AssemblyComponentDefinition
Dim oCompPtDef As PartComponentDefinition
'cycle each Origin plane in the first level Occurence in the assembly
For Zähler2 = 1 To 3
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oCompAsmDef = oOcc.Definition
	oOcc.CreateGeometryProxy(oCompAsmDef.WorkPlanes.Item(Zähler2),curCompOriPlane)
ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oCompPtDef = oOcc.Definition
	oOcc.CreateGeometryProxy(oCompPtDef.WorkPlanes.Item(Zähler2),curCompOriPlane)
End If
	'Measure distance
	Dim oNV As NameValueMap
'	Dim Distance As Double
'	Try
'Dim angle As Double = ThisApplication.MeasureTools.
	Dim angle As Double = ThisApplication.MeasureTools.GetAngle(curAsmorPlane, curCompOriPlane)
	'Angle in deg
'	MsgBox(angle)
	angle = (angle * 180) / PI
	If angle=0 Then
				'Convert distance from database units to default units of the document
				Dim Distance1 As Double = ThisApplication.MeasureTools.GetMinimumDistance(curAsmorPlane, curCompOriPlane)
				Dim oConstraint As AssemblyConstraint
				Distance = oUM.ConvertUnits(Distance1, UnitsTypeEnum.kDatabaseLengthUnits, oUM.LengthUnits)
				'Return the value in a messagebox just to control that it's right
				Distance= Round(Distance,3)
'				MsgBox(Distance)
				oConstraint=oAsmComp.Constraints.AddMateConstraint(curAsmorPlane, curCompOriPlane, Distance1)
		      If oConstraint.HealthStatus = oConstraint.HealthStatus.kInconsistentHealth Then
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddMateConstraint(curAsmorPlane, curCompOriPlane, -Distance1)
			  End If
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddFlushConstraint(curAsmorPlane, curCompOriPlane, Distance1)
			  End If
	          oConstraint.Delete
			  oConstraint = oAsmComp.Constraints.AddFlushConstraint(curAsmorPlane, curCompOriPlane, -Distance1)
			  End If
	          oConstraint.Delete
			  End If
	  End If
'	Catch
'	End Try
	Next
Next
'Try
	oOcc.Grounded = False
'	Catch
'		End try
Next
End Sub
second code for the Occurence eulerian angle adapted from her:
https://adndevblog.typepad.com/manufacturing/2013/01/inventor-eulerian-angles-of-assembly-component....
Sub Main()
    Dim oDoc As AssemblyDocument
     oDoc = ThisApplication.ActiveDocument
     	oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a oOcc plate")
    Dim oMat As Matrix
     oMat = oOcc.Transformation
    Dim aRotAngles(2) As Double
    Call CalculateRotationAngles(oMat, aRotAngles)
    ' Print results
'    Dim i As Integer
'    For i = 0 To 2
      msgbox(aRotAngles(0)  & vbCrLf & aRotAngles(1) & vbCrLf & aRotAngles(2))
'    Next i
    Beep
End Sub
Sub CalculateRotationAngles(ByVal oMatrix As Inventor.Matrix,ByRef aRotAngles() As Double)
    Const PI = 3.14159265358979
    Const TODEGREES As Double = 180 / PI
    Dim dB As Double
    Dim dC As Double
    Dim dNumer As Double
    Dim dDenom As Double
    Dim dAcosValue As Double
    Dim oRotate As Inventor.Matrix
    Dim oAxis As Inventor.Vector
    Dim oCenter As Inventor.Point
     oRotate = ThisApplication.TransientGeometry.CreateMatrix
     oAxis = ThisApplication.TransientGeometry.CreateVector
     oCenter = ThisApplication.TransientGeometry.CreatePoint
    oCenter.X = 0
    oCenter.Y = 0
    oCenter.Z = 0
    ' Choose aRotAngles[0] about x which transforms axes[2] onto the x-z plane
    dB = oMatrix.Cell(2, 3)
    dC = oMatrix.Cell(3, 3)
    dNumer = dC
    dDenom = Sqrt(dB * dB + dC * dC)
    ' Make sure we can do the division.  If not, then axes[2] is already in the x-z plane
    If (Abs(dDenom) <= 0.000001) Then
        aRotAngles(0) = 0#
    Else
        If (dNumer / dDenom >= 1#) Then
            dAcosValue = 0#
        Else
            If (dNumer / dDenom <= -1#) Then
                dAcosValue = PI
            Else
                dAcosValue = Acos(dNumer / dDenom)
            End If
        End If
        aRotAngles(0) = Sign(dB) * dAcosValue
        oAxis.X = 1
        oAxis.Y = 0
        oAxis.Z = 0
        Call oRotate.SetToRotation(aRotAngles(0), oAxis, oCenter)
        Call oMatrix.PreMultiplyBy(oRotate)
    End If
    ' Choose aRotAngles[1] about y which transforms axes[3] onto the z axis
    If (oMatrix.Cell(3, 3) >= 1#) Then
        dAcosValue = 0#
    Else
        If (oMatrix.Cell(3, 3) <= -1#) Then
            dAcosValue = PI
        Else
            dAcosValue = Acos(oMatrix.Cell(3, 3))
        End If
    End If
    aRotAngles(1) = Math.Sign(-oMatrix.Cell(1, 3)) * dAcosValue
    oAxis.X = 0
    oAxis.Y = 1
    oAxis.Z = 0
    Call oRotate.SetToRotation(aRotAngles(1), oAxis, oCenter)
    ' Choose aRotAngles[2] about z which transforms axes[0] onto the x axis
    If (oMatrix.Cell(1, 1) >= 1#) Then
        dAcosValue = 0#
    Else
        If (oMatrix.Cell(1, 1) <= -1#) Then
            dAcosValue = PI
        Else
            dAcosValue = Acos(oMatrix.Cell(1, 1))
        End If
    End If
    aRotAngles(2) = Math.Sign(-oMatrix.Cell(2, 1)) * dAcosValue
    'if you want to get the result in degrees
    aRotAngles(0) = Round(aRotAngles(0) * TODEGREES,4)
    aRotAngles(1) = Round(aRotAngles(1) * TODEGREES,4)
    aRotAngles(2) = Round(aRotAngles(2) * TODEGREES,4)
End Sub
Public Function Acos(value) As Double
    Acos = Math.Atan(-value / Math.Sqrt(-value * value + 1)) + 2 * Math.Atan(1)
End Function
Replies (25)
Message 2 of 26
SevInventor
got the solution,
Sub Main
For Each öConstraint In oAsmComp.Constraints
öConstraint.Delete
Next
oLODRep.Activate
Next
	Dim oTransform As Matrix
   	oTransform = oOcc.Transformation
	Dim oOriginLocation As Vector
	oOriginLocation = oTransform.Translation
Dim AbstandvonEbene(0 To 3) As Double
AbstandvonEbene(1) = oOriginLocation.X
AbstandvonEbene(2) = oOriginLocation.Y
AbstandvonEbene(3) = oOriginLocation.Z
For Zähler = 1 To 3
Dim curAsmOrPlane As WorkPlane = oAsmComp.WorkPlanes.Item(Zähler)
'oOcc.CreateGeometryProxy(curAsmOrPlane1, curAsmOrPlane)
	oOcc.CreateGeometryProxy(oCompPtDef.WorkPlanes.Item(Zähler2), curCompOriPlane)
End If
Dim oParalell As Boolean= curAsmOrPlane.Plane.IsParallelTo(curCompOriPlane.Plane, 0.00001)
Dim oSameDirection As Boolean= curAsmOrPlane.Plane.Normal.IsEqualTo(curCompOriPlane.Plane.Normal)
	If oParalell=True Then
				If oSameDirection=True Then
				oConstraint=oAsmComp.Constraints.AddFlushConstraint(curAsmOrPlane, curCompOriPlane, AbstandvonEbene(Zähler))
				End If
				If oSameDirection=False Then
				oConstraint=oAsmComp.Constraints.AddMateConstraint(curAsmOrPlane, curCompOriPlane, AbstandvonEbene(Zähler))
				End If
	  End If
	Next
Next
Next
End Sub
Message 3 of 26
ts2.cad3
First of all thank you very much for this solution. It is truly a very useful job!
I would need help with a small modification. Basically I would like to know how to modify the code to constrain the origin planes of the parts with an origin planes of an "Alpha" part instead of the origin of the parent assembly. It would be very convenient to be able to reposition parts in assemblies that are not centered at the origin
Message 4 of 26
SevInventor
Yes, there is some code here:
https://modthemachine.typepad.com/my_weblog/2009/04/positioning-assembly-occurrences.html
ive adapted it to work in ilogic. This one doesn't decide if flush or mate and does not measure the actual distance between occurences. Maybe you can use the code above.and this one to get what you want.
Sub main()
    Dim assemblydoc As AssemblyDocument
     assemblydoc = ThisApplication.ActiveDocument
    ' Get the occurrences in the select set.
    Dim occurrenceList As New Collection
    Dim entity As Object
    For Each entity In assemblydoc.SelectSet
        If TypeOf entity Is ComponentOccurrence Then
            occurrenceList.Add(entity)
        End If
    Next
    If occurrenceList.Count < 2 Then
        MsgBox("At least two occurrences must be selected.")
        Exit Sub
    End If
    ' This assumes the first selected occurrence is the "base"
    ' and will constrain the base workplanes of all the other parts
    ' to the base workplanes of the first part. If there are
    ' constraints on the other they end up being over constrained.
    ' Get the planes from the base part and create proxies for them.
    Dim baseOccurrence As ComponentOccurrence
     baseOccurrence = occurrenceList.Item(1)
    Dim BaseXY As WorkPlane
    Dim BaseYZ As WorkPlane
    Dim BaseXZ As WorkPlane
    Call GetPlanes(baseOccurrence, BaseXY, BaseYZ, BaseXZ)
    Dim constraints As AssemblyConstraints
     constraints = assemblydoc.ComponentDefinition.Constraints
    ' Iterate through the other occurrences
    Dim i As Integer
    For i = 2 To occurrenceList.Count
        Dim thisOcc As ComponentOccurrence
         thisOcc = occurrenceList.Item(i)
        ' Move it to the base occurrence so that if the base is
        ' not fully constrained it shouldn't move when the flush
        ' constraints are added.
        thisOcc.Transformation = baseOccurrence.Transformation
        ' Get the planes from the occurrence
        Dim occPlaneXY As WorkPlane
        Dim occPlaneYZ As WorkPlane
        Dim occPlaneXZ As WorkPlane
        Call GetPlanes(thisOcc, occPlaneXY, occPlaneYZ, occPlaneXZ)
        ' Add the flush constraints.
        Call constraints.AddFlushConstraint(BaseXY, occPlaneXY, 0)
        Call constraints.AddFlushConstraint(BaseYZ, occPlaneYZ, 0)
        Call constraints.AddFlushConstraint(BaseXZ, occPlaneXZ, 0)
    Next
End Sub
' Utility function used by the AlignOccurrencesWithConstraints macro.
' Given an occurrence it returns the base work planes that are in
' the part or assembly the occurrence references.  It gets the
' proxies for the planes since it needs the work planes in the
' context of the assembly and not in the part or assembly document
' where they actually exist.
Private Sub GetPlanes(ByVal Occurrence As ComponentOccurrence, _
                      ByRef BaseXY As WorkPlane, _
                      ByRef BaseYZ As WorkPlane, _
                      ByRef BaseXZ As WorkPlane)
    ' Get the work planes from the definition of the occurrence.
    ' These will be in the context of the part or subassembly, not
    ' the top-level assembly, which is what we need to return.
     BaseXY = Occurrence.Definition.WorkPlanes.Item(3)
     BaseYZ = Occurrence.Definition.WorkPlanes.Item(1)
     BaseXZ = Occurrence.Definition.WorkPlanes.Item(2)
    ' Create proxies for these planes.  This will act as the work
    ' plane in the context of the top-level assembly.
    Call Occurrence.CreateGeometryProxy(BaseXY, BaseXY)
    Call Occurrence.CreateGeometryProxy(BaseYZ, BaseYZ)
    Call Occurrence.CreateGeometryProxy(BaseXZ, BaseXZ)
End Sub
Message 5 of 26
ts2.cad3
I try to set a selected occurence as base for constrain the other but i don't know why he didn't work :/
Any idea?
Sub
Main Dim oAsm As AssemblyDocument= ThisApplication.ActiveDocument On Error Resume Next 'get the active assembly Dim oAsmComp As AssemblyComponentDefinition= ThisApplication.ActiveDocument.ComponentDefinition For Each �Constraint In oAsmComp.Constraints �Constraint.Delete Next 'set the Master LOD active Dim oLODRep As LevelOfDetailRepresentation oLODRep = oAsmComp.RepresentationsManager.LevelOfDetailRepresentations.Item("Master") oLODRep.Activate 'Iterate through all of the top level occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmComp.Occurrences ' 'ground everything in the top level oOccurrence.Grounded = True Next ''''''''''''''''''''''''''''''''''''''''''''''' ' Get the occurrences in the select set. Dim occurrenceList As New Collection Dim entity As Object entity = oAsm.Select Dim baseOccurrence As ComponentOccurrence baseOccurrence = entity ''''''''''''''''''''''''''''''''''''''''''''''' Dim oUM As UnitsOfMeasure = oAsm.UnitsOfMeasure Dim oOcc As ComponentOccurrence For Each oOcc In oAsm.ComponentDefinition.Occurrences Dim oTransform As Matrix oTransform = oOcc.Transformation Dim oOriginLocation As Vector oOriginLocation = oTransform.Translation Dim AbstandvonEbene(0 To 3) As Double AbstandvonEbene(1) = oOriginLocation.X AbstandvonEbene(2) = oOriginLocation.Y AbstandvonEbene(3) = oOriginLocation.Z 'Create a proxy for Face0 (The face in the context of the assembly) Dim Z�hler As Integer = 1 'cycle each Origin plane in the top assembly For Z�hler = 1 To 3 Dim curAsmOrPlane As WorkPlane = baseOccurrence.WorkPlanes.Item(Z�hler) Dim oCompAsmDef As AssemblyComponentDefinition Dim oCompPtDef As PartComponentDefinition 'cycle each Origin plane in the first level Occurence in the assembly For Z�hler2 = 1 To 3 If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oCompAsmDef = oOcc.Definition oOcc.CreateGeometryProxy(oCompAsmDef.WorkPlanes.Item(Z�hler2),curCompOriPlane) ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then oCompPtDef = oOcc.Definition oOcc.CreateGeometryProxy(oCompPtDef.WorkPlanes.Item(Z�hler2), curCompOriPlane) End If Dim oParalell As Boolean= curAsmOrPlane.Plane.IsParallelTo(curCompOriPlane.Plane, 0.00001) Dim oSameDirection As Boolean= curAsmOrPlane.Plane.Normal.IsEqualTo(curCompOriPlane.Plane.Normal) Dim oNV As NameValueMap If oParalell=True Then If oSameDirection=True Then oConstraint=oAsmComp.Constraints.AddFlushConstraint(curAsmOrPlane, curCompOriPlane, AbstandvonEbene(Z�hler)) End If If oSameDirection=False Then oConstraint=oAsmComp.Constraints.AddMateConstraint(curAsmOrPlane, curCompOriPlane, AbstandvonEbene(Z�hler)) End If End If Next Next oOcc.Grounded = False Next End Sub Private Sub GetPlanes(ByVal Occurrence As ComponentOccurrence, _ ByRef BaseXY As WorkPlane, _ ByRef BaseYZ As WorkPlane, _ ByRef BaseXZ As WorkPlane) ' Get the work planes from the definition of the occurrence. ' These will be in the context of the part or subassembly, not ' the top-level assembly, which is what we need to return. BaseXY = Occurrence.Definition.WorkPlanes.Item(3) BaseYZ = Occurrence.Definition.WorkPlanes.Item(1) BaseXZ = Occurrence.Definition.WorkPlanes.Item(2) ' Create proxies for these planes. This will act as the work ' plane in the context of the top-level assembly. Call Occurrence.CreateGeometryProxy(BaseXY, BaseXY) Call Occurrence.CreateGeometryProxy(BaseYZ, BaseYZ) Call Occurrence.CreateGeometryProxy(BaseXZ, BaseXZ) End Sub
Message 6 of 26
WCrihfield
Hi @ts2.cad3.  I'm not 100% sure what your goal was there, but I'm pretty sure you want a way to specify a stationary component, then constrain one (or more) other components to that stationary component, by the proxies of their origin planes, while deleting any existing constraints that may have already been on the component that you want to move.  If that sounds accurate, then this rule should work for that task fairly well.  I chose not to label the WorkPlanes, because I often rename my origin WorkPlanes anyways to more useful useful names, and some folks may have their UCS & ViewCube system set-up differently than standard.  The code below is not currently set-up with a loop, but I believe it could be, if needed/wanted.  I placed a couple comments in key places that would likely be good places for beginning/ending a loop, if you were to use one.  Or it could be converted to get rid of the second Pick function, and just loop all other top level components (other than the stationary one).
Sub Main
	Dim oBaseComponent As ComponentOccurrence = PickComponent("Pick Base Component.")
	If IsNothing(oBaseComponent) Then Exit Sub
	Dim oADef As AssemblyComponentDefinition = oBaseComponent.Parent
	Dim oConsts As AssemblyConstraints = oADef.Constraints
	oTrans = ThisApplication.TransactionManager.StartTransaction(oADef.Document, "Constrain Components (API)")
	Dim oBaseWPPs As List(Of WorkPlaneProxy) = GetComponentOriginPlaneProxies(oBaseComponent)
	If IsNothing(oBaseWPPs) OrElse (Not oBaseWPPs.Count = 3) Then
		MsgBox("Failed to get 3 WorkPlaneProxy objects from Base component. Exiting.", vbCritical, "")
		oTrans.Abort
		Exit Sub
	End If
	Dim oBaseTrans As Matrix = oBaseComponent.Transformation
	'<<<< Good Point For Loop Of Remaining Code >>>>
	Dim oCompToMove As ComponentOccurrence = PickComponent("Pick Component To Move.")
	If IsNothing(oCompToMove) Then oTrans.Abort : Exit Sub
	Dim oCompToMoveWPPs As List(Of WorkPlaneProxy) = GetComponentOriginPlaneProxies(oCompToMove)
	If IsNothing(oCompToMoveWPPs) OrElse (Not oCompToMoveWPPs.Count = 3) Then
		MsgBox("Failed to get 3 WorkPlaneProxy objects from component to move. Exiting.", vbCritical, "")
		oTrans.Abort
		Exit Sub
	End If
	DeleteConstraints(oCompToMove)
	oCompToMove.Transformation = oBaseTrans
	For i As Integer = 0 To 2
		oConst = oConsts.AddFlushConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i), 0)
	Next
	'<<<< End Loop Here, If Using One >>>>
	oTrans.End
End Sub
Function PickComponent(oPrompt As String) As ComponentOccurrence
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, oPrompt)
	If IsNothing(oObj) OrElse (TypeOf oObj Is ComponentOccurrence = False) Then Return Nothing
	Dim oOcc As ComponentOccurrence = oObj
	Return oOcc
End Function
Function GetComponentOriginPlaneProxies(oComp As ComponentOccurrence) As List(Of WorkPlaneProxy)
	If IsNothing(oComp) Then Return Nothing
	Dim oWPs As WorkPlanes = Nothing
	Dim oWPPs As New List(Of WorkPlaneProxy)
	If TypeOf oComp.Definition Is PartComponentDefinition Or _
		TypeOf oComp.Definition Is AssemblyComponentDefinition Then
		oWPs = oComp.Definition.WorkPlanes
	Else
		Return Nothing
	End If
	For i As Integer = 1 To 3
		Dim oWPP As WorkPlaneProxy = Nothing
		oWP = oWPs.Item(i)
		oComp.CreateGeometryProxy(oWP, oWPP)
		oWPPs.Add(oWPP)
	Next
	Return oWPPs
End Function
Sub DeleteConstraints(oComp As ComponentOccurrence)
	If IsNothing(oComp) Then Exit Sub
	If oComp.Constraints.Count = 0 Then Exit Sub
	For Each oConst As AssemblyConstraint In oComp.Constraints
		oConst.Delete
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 7 of 26
ts2.cad3
Hi  WCrihfield, thank for you for your reply.
My goal is to constrain the origin planes of one or more parts of an assembly to the origin planes of a base component but to the relative distance / position in which they are at the moment of the execution of the rule.
The code you posted works fine, I should find a way to measure relative distances before placing the constraint.
Message 8 of 26
SevInventor
to check if the workplanes are parallel and facing the same direction something like this is missing. Also the loop has to go trough all base Workplanes and all target Workplanes. because each of them could be parallel
				End If
				End If
	  End If
	Next
Next
the distance between base Occurence and the the target Occurence could be calculated through component transformation. But i don't know exactly how.
Message 9 of 26
ts2.cad3
Ok this seems to work (sometimes):
Sub Main
        oTrans.Abort
        Exit Sub
    End If
    '''    Dim oAsmComp As AssemblyComponentDefinition= ThisApplication.ActiveDocument.ComponentDefinition
    Next
    '''    '<<<< Good Point For Loop Of Remaining Code >>>>
'''    Dim oCompToMove As ComponentOccurrence = PickComponent("Pick Component To Move.")'''    If IsNothing(oCompToMove) Then oTrans.Abort : Exit Sub'''    Dim oCompToMoveWPPs As List(Of WorkPlaneProxy) = GetComponentOriginPlaneProxies(oCompToMove)'''    If IsNothing(oCompToMoveWPPs) OrElse (Not oCompToMoveWPPs.Count = 3) Then'''        MsgBox("Failed to get 3 WorkPlaneProxy objects from component to move. Exiting.", vbCritical, "")'''        oTrans.Abort'''        Exit Sub'''    End If
'''    DeleteConstraints(oCompToMove)'''    oCompToMove.Transformation = oBaseTrans'''
'''    For i As Integer = 0 To 2'''        oConst = oConsts.AddFlushConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i), 0)'''    Next
        For Z�hler = 1 To 3
            Dim oBaseWPPstOrPlane As WorkPlane = oBaseWPPs(Z�hler)
            'cycle each Origin plane of base component in the first level Occurence in the assembly
                End If
                Dim oParalell As Boolean= oBaseWPPstOrPlane.Plane.IsParallelTo(curCompOriPlane.Plane, 0.00001)
                Dim oSameDirection As Boolean= oBaseWPPstOrPlane.Plane.Normal.IsEqualTo(curCompOriPlane.Plane.Normal)
                    End If
                    End If
                End If
            Next
        Next
Next
'''    '<<<< End Loop Here, If Using One >>>>
    oTrans.End
End Sub
    Return oOcc
End Function
    Else
        Return Nothing
    End If
        oWP = oWPs.Item(i)
        oWPPs.Add(oWPP)
    Next
    Return oWPPs
End Function
        oConst.Delete
    Next
End Sub
Message 10 of 26
SevInventor
This is state so far:
Sub Main
		oBaseComponent.Grounded = True
		oTrans.Abort
		Exit Sub
	End If
		oCompToMove.Grounded = True
		oTrans.Abort
		Exit Sub
	End If
	Dim oCompToMoveTrans As Matrix = oCompToMove.Transformation
	Dim oLocationBase As Vector
    oLocationBase = oBaseTrans.Translation
    oOriginLocation = oCompToMoveTrans.Translation
    Dim Calcdistance(0 To 2) As Double
    Calcdistance(0) = (oLocationBase.X-oOriginLocation.X)*(-1)
    Calcdistance(1) = (oLocationBase.Y-oOriginLocation.Y)*(-1)
    Calcdistance(2) = (oLocationBase.Z-oOriginLocation.Z)*(-1)
		For i2 As Integer = 0 To 2
		Dim oParallel As Boolean = oBaseWPPs.Item(i).Plane.IsParallelTo(oCompToMoveWPPs.Item(i2).Plane, 0.00001)
		Dim oSameDirection As Boolean=False
		oSameDirection= oBaseWPPs.Item(i).Plane.Normal.IsEqualTo(oCompToMoveWPPs.Item(i2).Plane.Normal)
		If oParallel=True Then
				oConstraint=oConsts.AddFlushConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i2), Calcdistance(i))
				End If
				oConstraint=oConsts.AddMateConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i2), Calcdistance(i))
				End If
	  End If
	Next
MsgBox(Calcdistance(i))
	Next
	oTrans.End
End Sub
	Return oOcc
End Function
	Else
		Return Nothing
	End If
		oWP = oWPs.Item(i)
		oWPPs.Add(oWPP)
	Next
	Return oWPPs
End Function
		oConst.Delete
	Next
End Sub
 The Calcdistance(i) is not in the right sequence because the originplanes are not like the originplanes of the top level assembly
Message 11 of 26
ts2.cad3
Magnifico!!!!
Message 12 of 26
ts2.cad3
Ok i just made some little modification to your last code to reiterate in all the component of the assembly.
Thank you very much whitout your help it would have been impossible for me !!!
Sub Main()
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Dim oTrans As Transaction
    Dim oConst As FlushConstraint
    Dim kDefaultDisplayLengthUnits As Object
    Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    If asmDoc.SelectSet.Count = 0 Then
        MsgBox("Need to select a Part or Sub Assembly")
        Return
    End If
        Return
    End If
    Try
        AlignOccurrencesWithConstraints()
        Next
    Catch ex As Exception
       ' MsgBox("Is the selected item a Component?")
        MsgBox(ex.ToString())
        Return
    End Try
End Sub
Sub AlignOccurrencesWithConstraints()
        Dim assemblydoc As AssemblyDocument = ThisApplication.ActiveDocument
            End If
        Next
            Exit Sub
        End If
        Dim baseOccurrence As ComponentOccurrence = occurrenceList.Item(1)
        Dim constraints As AssemblyConstraints = assemblydoc.ComponentDefinition.Constraints
        Dim i As Integer
            Dim thisOcc As ComponentOccurrence = occurrenceList.Item(i)
            ConstrPlanes(baseOccurrence, thisOcc)
        Next
    End Sub
Public Sub ConstrPlanes(ByVal baseOccurrence As ComponentOccurrence,ByVal thisOcc As ComponentOccurrence)
    Dim oBaseComponent As ComponentOccurrence = baseOccurrence
        oTrans.Abort
        Exit Sub
    End If
    Dim oCompToMove As ComponentOccurrence = thisOcc
        oTrans.Abort
        Exit Sub
    End If
                End If
                End If
      End If
    Next
    Next
    oTrans.End
End Sub
    Return oOcc
End Function
    Else
        Return Nothing
    End If
        oWP = oWPs.Item(i)
        oWPPs.Add(oWPP)
    Next
    Return oWPPs
End Function
        oConst.Delete
    Next
End Sub
Message 13 of 26
WCrihfield
Hi @ts2.cad3.  This has been an interesting task to tackle.  I originally did not realize you needed to maintain relative distances and relative orientations between base component and the other component.  But the resulting code I created is probably useful to some folks with a slightly different task to tackle.  And I also was not sure if you really intended to constrain 'all' other components to the base component, or just one, or just a select few.  So, I altered my code to get rid of the second Pick function, and instead just loop through all other components in the assembly, to constrain them all to the one selected base component.  Then streamlined the rest of the code a bit, and incorporated the parallel and direction difference checks into it, but did the offset calculation a bit simpler.
  Also, out of interest I continued looking into this task, and threw in a potential stumbling block into it as a test.  What about if you have an OccurrencePattern in your assembly?  So, in a test assembly file, I created a simple RectangularOccurrencePattern and attempted to update my code to deal with that situation, which would definitely trip up a simpler code.  The position of an OccurrencePatternElement object is set/controlled by the pattern, and often do not have any constraints on them to keep them in place.  Only the original input component(s) that you specified to create the pattern of will usually be constrained, and attempting to constrain any of the pattern elements will result in errors, due to becoming over constrained.  So, I created a custom Function to use as a sort of a 'filter' or 'checker' in this situation, to avoid that potential problem.  I also left most of my comment lines in that Function code, because it can be hard to follow/understand what's going on (the train of thought).
Here is the resulting code, just in case you guys may find it helpful.  I attached it as a Text file, because of how long it is, but if you can't download it, I can post it directly.
Wesley Crihfield
Message 14 of 26
SevInventor
Hello WCrihfield,
Ive tested your code and it doesn't maintain relative distances and relative orientations between ba...
So I've adapted my previous code with your better offset calculation. Now it works for me.
One missing step is to select more than one component to constrain to the base component.
Sub Main
		oTrans.Abort
		Exit Sub
	End If
		oTrans.Abort
		Exit Sub
	End If
		oOffSet = oBaseWPPs.Item(i).Plane.DistanceTo(oCompToMoveWPPs.Item(i2).Plane.RootPoint)
				oConstraint=oConsts.AddFlushConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i2), oOffSet)
				End If
				oConstraint=oConsts.AddMateConstraint(oBaseWPPs.Item(i), oCompToMoveWPPs.Item(i2), oOffSet)
				End If
	  			End If
		Next
	Next
	oTrans.End
	oCompToMove.Grounded = False
	oBaseComponent.Grounded = False
End Sub
	Return oOcc
End Function
	Else
		Return Nothing
	End If
		oWP = oWPs.Item(i)
		oWPPs.Add(oWPP)
	Next
	Return oWPPs
End Function
		oConst.Delete
	Next
End Sub
Message 15 of 26
WCrihfield
OK.  My code worked just fine for me.  None of the components moved any at all, and it even constrained the component that I had created a component pattern of, so that the whole pattern would also maintain its position & orientation with the base component.  I did notice however, that your code includes lines of code for grounding every component it encounters, including the base component, but then still utilizing the Sub to delete all other constraints on each 'other' component.  But then there are two lines of code at the very end of your Sub Main area to turn off the 'ground' setting for the Base component, and the other component.  But it seems to me that the line to turn off the ground setting for the other component would only effect the very last 'other' component, because it is after all of the loops, not within the loops.  So...are all the 'other' components remaining 'grounded' in your results?
I just had no need to ground anything in my testing scenarios, because I had already fully constrained my base component (and sometimes the other components too) ahead of time, knowing my plans for it, and I was confident that none of the others would move, because I am measuring the offsets before applying the constraints.  However, this type of code still is not all encompassing,  because it does not address any components that may not be perfectly aligned parallel/perpendicular to the origin planes of the base component.  I also considered using the UCS to UCS type constraints, while looking into this case.  It seemed like more work was involved, and you have to create a UCS for each component (within the main assembly) to use ahead of time, which is similar to a work feature.  It's fairly easy to create them though, using the components transformation matrix, and you end up with an object with a lot of useful properties.
Wesley Crihfield
Message 16 of 26
ts2.cad3
hI WCrihfield, I have done various tests with your code and it works perfectly even in case there are in the set of series. You did a great job, thank you very much!
there would be only one case that should be further inspected, that is the case in which the origin planes of a component are not "aligned" with those of the base component. Probably a way could be found to constrain in this case, the point of origin of the component not "aligned" with the origin planes of the base component. It would still remain "rotatable" on its point of origin but at least it would keep the relative maximum position.
Message 17 of 26
Rich-T
This code is very useful.
Have you got a version with the loop to allow multiple selections to be made ?
Message 18 of 26
SevInventor
almost. there are some errors
Sub Main
	oDoc = ThisDoc.Document
	Dim oOccCol As Inventor.ObjectCollection
	oOccCol = ThisApplication.TransientObjects.CreateObjectCollection
		oTrans.Abort
		Exit Sub
	End If
Do
	'Ask user for a selection
	oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component :")
	If Not oOcc Is  Nothing Then
	'Add component to collection
	oOccCol.Add(oOcc)
	'Set selected component inactive
	oOcc.Enabled = False
	End If
	Loop While Not oOcc Is Nothing
	'Add collection to selection
	oDoc.SelectSet.SelectMultiple(oOccCol)
	oSelSet = oDoc.SelectSet
For Each oOcc In oSelSet
		oOcc.Grounded = True
	Dim oOccWPPs As List(Of WorkPlaneProxy) = GetComponentOriginPlaneProxies(oOcc)
	If IsNothing(oOccWPPs) OrElse (Not oOccWPPs.Count = 3) Then
		oTrans.Abort
		Exit Sub
	End If
'	DeleteConstraints(oOcc)
		Dim oParallel As Boolean = oBaseWPPs.Item(i).Plane.IsParallelTo(oOccWPPs.Item(i2).Plane, 0.00001)
		oSameDirection= oBaseWPPs.Item(i).Plane.Normal.IsEqualTo(oOccWPPs.Item(i2).Plane.Normal)
		oOffSet = oBaseWPPs.Item(i).Plane.DistanceTo(oOccWPPs.Item(i2).Plane.RootPoint)
'		msgbox(oOffset)
				If oSameDirection = True Then
					Try
				oConstraint = oConsts.AddFlushConstraint(oBaseWPPs.Item(i), oOccWPPs.Item(i2), oOffSet)
				Catch
					End Try
				End If
				If oSameDirection = False Then
					Try
				oConstraint = oConsts.AddMateConstraint(oBaseWPPs.Item(i), oOccWPPs.Item(i2), oOffSet)
				Catch
					end try
				End If
	  			End If
		Next
	Next
	oOcc.Enabled = True
	Next
	oDoc.SelectSet.Clear
	oTrans.End
End Sub
    Return oOcc
End Function
    Else
        Return Nothing
    End If
        oWP = oWPs.Item(i)
        oWPPs.Add(oWPP)
    Next
    Return oWPPs
End Function
        oConst.Delete
    Next
End Sub
maybe you can fix it.
Message 19 of 26
WCrihfield
Hi guys.  I also did a bit more work on this project the other day, but chose not to publish my code yet at that time, because it was still a work in progress, and still needs more R&D.  I was attempting to solve the issue of when the 'other' component's origin planes are not parallel with the 'base' component's origin planes.  I also incorporated the 'grounding' steps suggested by @SevInventor, figuring that it probably wouldn't hurt anything.  I further developed the routine for creating the constraints between the origin planes, out in its own Sub, by incorporating measuring angles and using angle constraints.  Then, after seeing that was still not enough to fully constrain everything, I created an additional, but similar Sub routine for constraining the origin WorkAxes.  This still was not fully constraining those certain few components that were deliberately not aligned in any way with the 'base' component, and left a lot of 'Redundant' constraints in place.  It is also still set-up to loop through all other components, other than the one selected 'base' component, to constrain them all relatively to that base component, rather than selecting multiple components up front to process.  For what its worth, I have pasted the code I had developed so far into a Text File, and attached it to this post for others to revue, and possibly further develop if they want.
I don't think that re-considering using the UCS to UCS constraint system will help here either, because the documentation about it says that it essentially creates a 'constraints set' consisting of 'three flush constraints' between either UCS's, component origins, or assembly origin.  That doesn't sound any better than what we've already developed here.  Plus, the other odd thing about that route, is that there does not appear to be an Inventor API method for creating them directly...just an iLogic only snippet, which returns an 'IManagedConstraint', instead of a regular AssemblyConstraint.  I think there just needs to be a new or better constraint type, just for this specific purpose...constraining one component to another, while maintaining exact existing offsets, angles, and orientations, even if they are not aligned with each other in any way.
Wesley Crihfield
Message 20 of 26
SevInventor
@WCrihfield, realy great work!
Happy Easter
