application option screen in inventor 2014
Message 1 of 12
hi
I started use inventor 2014 last few weeks ( that what I have )
I have only one button --  apply butten
how can I fix this problem?
thanks
shuki
Accepted solutions (3)
Replies (11)
Message 2 of 12
bradeneuropeArthur
Please give a little more details in what your problem is.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
thanks for your help
I have just installed inventor 2014 .
When I operate the application option screen I only get the 'apply' button and I can't make or save changes that would enable a working environment suited to my needs.
shuki
Message 4 of 12
bradeneuropeArthur
Please make a screenshot
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
hi
I  paste pdf file that show the screen
thank you
shuki
Message 6 of 12
bradeneuropeArthur
social.msdn.microsoft.com/Forums/windows/en-US/3e16c089-f341-4edd-a6ba-f371cebf85f8/missing-buttons-on-a-windows-forms-form?forum=winforms
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
bradeneuropeArthur
As I can see you are using a different system language than English, because your taskbar (in the bottom) is from right to left, correct?
This can be related to the issue.
please set your system language to English and restart your system.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 12
thank you
I did set  system language to English and restart the system.
it solve the problem.
Now that the problem and the solution are known
Perhaps there is a solution that will enable me to work in a different system language than English?
Message 9 of 12
bradeneuropeArthur
Can you marked it as solved than please
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 12
thanks again
You were a great help
Can not find the button to marked it as solved
this problem is solved
shuki
Message 11 of 12
bradeneuropeArthur
@Anonymous
What is your country?
You can change the country without influence to the language settings too: in the Region & Language settings.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 12
Thank you
I'm from Israel - in Hebrew, writing from right to left, and it produces a lot of compatibility problems with the operating system
I am learning the possibility to work so that the operating system in English
It seems to me that this is the optimal situation
Thanks again
shuki
