I have change the most crucial things.
Question:
Do you know how add ins work.
The very basic things are missing, so it seems to me that you need training first!!!
please let me know what level of understanding you have with add ins programming.
- No experience
- little
- beginner
- advanced user
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports Microsoft.VisualBasic.Compatibility.VB6
Namespace InventorAddIn1
<ProgIdAttribute("InventorAddIn1.StandardAddInServer"),
GuidAttribute("96dccdbb-dabe-4a88-95bf-c292d8b41f9f")>
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
Private WithEvents m_uiEvents As UserInterfaceEvents
Private WithEvents m_sampleButton As ButtonDefinition
#Region "ApplicationAddInServer Members"
' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
' the first time. However, with the introduction of the ribbon this argument is always true.
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' Initialize AddIn members.
g_inventorApplication = addInSiteObject.Application
' Connect to the user-interface events to handle a ribbon reset.
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
' TODO: Add button definitions.
' Sample to illustrate creating a button definition.
Dim largeIcon As Inventor.IPictureDisp = IconToIPicture(New System.Drawing.Icon(My.Resources.YourSmallImage, 32, 32))
Dim smallIcon As Inventor.IPictureDisp = IconToIPicture(New System.Drawing.Icon(My.Resources.YourSmallImage, 16, 16))
Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
m_sampleButton = controlDefs.AddButtonDefinition("Command Name", "Internal Name", CommandTypesEnum.kShapeEditCmdType, AddInClientID)
' Add to the user interface, if it's the first time.
If firstTime Then
AddToUserInterface()
End Sub
' This method is called by Inventor when the AddIn is unloaded. The AddIn will be
' unloaded either manually by the user or when the Inventor session is terminated.
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' TODO: Add ApplicationAddInServer.Deactivate implementation
' Release objects.
m_uiEvents = Nothing
g_inventorApplication = Nothing
System.GC.Collect()
System.GC.WaitForPendingFinalizers()
End Sub
' This property is provided to allow the AddIn to expose an API of its own to other
' programs. Typically, this would be done by implementing the AddIn's API
' interface in a class and returning that class object through this property.
Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
Get
Return Nothing
End Get
End Property
' Note:this method is now obsolete, you should use the
' ControlDefinition functionality for implementing commands.
Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
End Sub
#End Region
#Region "User interface definition"
' Sub where the user-interface creation is done. This is called when
' the add-in loaded and also if the user interface is reset.
Private Sub AddToUserInterface()
' This is where you'll add code to add buttons to the ribbon.
'** Sample to illustrate creating a button on a new panel of the Tools tab of the Part ribbon.
'' Get the part ribbon.
Dim partRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Part")
'' Get the "Tools" tab.
Dim toolsTab As RibbonTab = partRibbon.RibbonTabs.Item("id_TabTools")
'' Create a new panel.
Dim customPanel As RibbonPanel = toolsTab.RibbonPanels.Add("Sample", "MysSample", AddInClientID)
'' Add a button.
customPanel.CommandControls.AddButton(m_sampleButton)
End Sub
Private Sub m_uiEvents_OnResetRibbonInterface(Context As NameValueMap) Handles m_uiEvents.OnResetRibbonInterface
' The ribbon was reset, so add back the add-ins user-interface.
End Sub
' Sample handler for the button.
Private Sub m_sampleButton_OnExecute(Context As NameValueMap) Handles m_sampleButton.OnExecute
MsgBox("Button was clicked.")
End Sub
#End Region
End Class
End Namespace
Public Module Globals
' Inventor application object.
Public g_inventorApplication As Inventor.Application
#Region "Function to get the add-in client ID."
' This function uses reflection to get the GuidAttribute associated with the add-in.
Public Function AddInClientID() As String
Dim guid As String = ""
Try
Dim t As Type = GetType(InventorAddIn1.StandardAddInServer)
Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False)
Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute)
guid = "{" + guidAttribute.Value.ToString() + "}"
Catch
End Try
Return guid
End Function
#End Region
#Region "hWnd Wrapper Class"
' This class is used to wrap a Win32 hWnd as a .Net IWind32Window class.
' This is primarily used for parenting a dialog to the Inventor window.
' For example:
' myForm.Show(New WindowWrapper(g_inventorApplication.MainFrameHWND))
Public Class WindowWrapper
Implements System.Windows.Forms.IWin32Window
Public Sub New(ByVal handle As IntPtr)
_hwnd = handle
End Sub
Public ReadOnly Property Handle() As IntPtr _
Implements System.Windows.Forms.IWin32Window.Handle
Get
Return _hwnd
End Get
End Property
Private _hwnd As IntPtr
End Class
#End Region
#Region "Image Converter"
#End Region
End Module
