Fillet Feature (Complex) API Sample
not the edit dialog itself but via code
Public Sub CreateFilletComplex()
' Create a new Part document.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the compdef.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a sketch on the xy work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
' Draw a rectangle.
Dim oEnts As SketchEntitiesEnumerator
Set oEnts = oSketch.SketchLines.AddAsTwoPointRectangle( _
ThisApplication.TransientGeometry.CreatePoint2d(-6, -4), _
ThisApplication.TransientGeometry.CreatePoint2d(6, 4))
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create an extrusion.
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(8, kSymmetricExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
' Create an EdgeCollection object to use for inputting the edges for fillets.
Dim oEdgeCollection As EdgeCollection
Set oEdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection
' Add all of the edges of the start face to the edge collection.
Dim oEdge As Edge
For Each oEdge In oExtrude.StartFaces.Item(1).Edges
oEdgeCollection.Add oEdge
Next
' Obtain a FilletDefinition object to use in defining the various inputs to create the fillet.
Dim oFilletDef As FilletDefinition
Set oFilletDef = oCompDef.Features.FilletFeatures.CreateFilletDefinition
' Create the first edge set.
Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 1.5)
' Reinitialize the edge collection.
' Add all of the edges of the end face to the edge collection.
For Each oEdge In oExtrude.EndFaces.Item(1).Edges
Next
Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 1)
' Find the edges that go between the start and end faces by checking to
' see if they're parallel to the Z axis.
Dim oZVector As UnitVector
Set oZVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 0, 1)
Dim oSideEdges(1 To 4) As Edge
Dim EdgeCount As Long
EdgeCount = 0
For Each oEdge In oCompDef.SurfaceBodies.Item(1).Edges
' In this case we know all the edges are linear.
Dim oLine As LineSegment
Set oLine = oEdge.Geometry
If oLine.Direction.IsParallelTo(oZVector) Then
EdgeCount = EdgeCount + 1
Set oSideEdges(EdgeCount) = oEdge
Next
' Add the first two edges to a constant radius edge set.
oEdgeCollection.Add oSideEdges(1)
oEdgeCollection.Add oSideEdges(2)
Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 0.5)
' Create a variable radius edge set for the third edge.
oEdgeCollection.Add oSideEdges(3)
Call oFilletDef.AddVariableRadiusEdgeSet(oEdgeCollection, 1, 2)
' Create a variable radius edge with a different internal radius for the fourth edge.
oEdgeCollection.Add oSideEdges(4)
Dim oVarRadiusEdgeSet As FilletVariableRadiusEdgeSet
Set oVarRadiusEdgeSet = oFilletDef.AddVariableRadiusEdgeSet(oEdgeCollection, 0.5, 1.5)
Call oVarRadiusEdgeSet.AddIntermediateRadius(oSideEdges(4), 3, 0.5)
Dim oFillet As FilletFeature
Set oFillet = oCompDef.Features.FilletFeatures.Add(oFilletDef, False)
End Sub
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
