API to edit a feature
MattH_Work
MattH_Work
If I have a feature name (Fillet2, Extrude2 etc) can I open the 'edit' dialog for that feature via VB
Cheers
Matt
MattH
Product Design Collection 2026
Vault Pro 2026
Ruffy85
Fillet Feature (Complex) API Sample
not the edit dialog itself but via code
Public Sub CreateFilletComplex()
    ' Create a new Part document.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the compdef.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a sketch on the xy work plane.
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
    ' Draw a rectangle.
    Dim oEnts As SketchEntitiesEnumerator
    Set oEnts = oSketch.SketchLines.AddAsTwoPointRectangle( _
                            ThisApplication.TransientGeometry.CreatePoint2d(-6, -4), _
                            ThisApplication.TransientGeometry.CreatePoint2d(6, 4))
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    ' Create an extrusion.
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
    Call oExtrudeDef.SetDistanceExtent(8, kSymmetricExtentDirection)
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
    ' Create an EdgeCollection object to use for inputting the edges for fillets.
    Dim oEdgeCollection As EdgeCollection
    Set oEdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection
    ' Add all of the edges of the start face to the edge collection.
    Dim oEdge As Edge
    For Each oEdge In oExtrude.StartFaces.Item(1).Edges
        oEdgeCollection.Add oEdge
    Next
    ' Obtain a FilletDefinition object to use in defining the various inputs to create the fillet.
    Dim oFilletDef As FilletDefinition
    Set oFilletDef = oCompDef.Features.FilletFeatures.CreateFilletDefinition
    ' Create the first edge set.
    Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 1.5)
    ' Reinitialize the edge collection.
    ' Add all of the edges of the end face to the edge collection.
    For Each oEdge In oExtrude.EndFaces.Item(1).Edges
    Next
    Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 1)
    ' Find the edges that go between the start and end faces by checking to
    ' see if they're parallel to the Z axis.
    Dim oZVector As UnitVector
    Set oZVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 0, 1)
    Dim oSideEdges(1 To 4) As Edge
    Dim EdgeCount As Long
    EdgeCount = 0
    For Each oEdge In oCompDef.SurfaceBodies.Item(1).Edges
        ' In this case we know all the edges are linear.
        Dim oLine As LineSegment
        Set oLine = oEdge.Geometry
        If oLine.Direction.IsParallelTo(oZVector) Then
            EdgeCount = EdgeCount + 1
            Set oSideEdges(EdgeCount) = oEdge
        End If
    Next
    ' Add the first two edges to a constant radius edge set.
    oEdgeCollection.Add oSideEdges(1)
    oEdgeCollection.Add oSideEdges(2)
    Call oFilletDef.AddConstantRadiusEdgeSet(oEdgeCollection, 0.5)
    ' Create a variable radius edge set for the third edge.
    oEdgeCollection.Add oSideEdges(3)
    Call oFilletDef.AddVariableRadiusEdgeSet(oEdgeCollection, 1, 2)
    ' Create a variable radius edge with a different internal radius for the fourth edge.
    oEdgeCollection.Add oSideEdges(4)
    Dim oVarRadiusEdgeSet As FilletVariableRadiusEdgeSet
    Set oVarRadiusEdgeSet = oFilletDef.AddVariableRadiusEdgeSet(oEdgeCollection, 0.5, 1.5)
    Call oVarRadiusEdgeSet.AddIntermediateRadius(oSideEdges(4), 3, 0.5)
    Dim oFillet As FilletFeature
    Set oFillet = oCompDef.Features.FilletFeatures.Add(oFilletDef, False)
End Sub
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
MechMachineMan
Or you could use the code to get the browser node then:
.EnsureVisible
.DoSelect
and then run the control definition that is associated with editing features.
There is plenty of blogs around that explain the process. Some google-fu will get you there.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
