Addins to inventor 2024 and 2025
jose_loaiza5W6L6
jose_loaiza5W6L6
Hello cummunity I hope you are very well
I developed an addin to inventor 2024 using Framework 8 as a target, Now I would like to use that addin in inventor 2025; however, I read the documentation and I see that to develop an addin to inventor 2025 I should use NET Core 8. My question is, I must have two projects, one with .NET Framework 8 and the other with.NET .net core? or is there any approach to only having one project that works for both versions?
I appreciate any help with this doubt.
Thank you so much.
bradeneuropeArthur
@JelteDeJong has a good tutorial for this:
http://www.hjalte.nl/tutorials/95-compile-and-debug-multiple-net-versions
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
jose_loaiza5W6L6
Hello @JelteDeJong thank you for your answer; it was very helpful
