Export BOM with all levels into custom excel
sachin_kumar6CZM2
sachin_kumar6CZM2
Hi Experts,
i want to export my BOM with all levels into a custom excel template. i also wants to add custom i properties to the excel. i have used the following code..
Sub main()
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
    Exit Sub
Dim TemplateFolder As String = ThisApplication.DesignProjectManager.ActiveDesignProject.TemplatesPath
Dim ExcelTemplate As String = TemplateFolder &"\EDT_T-PA25-DT200_BoM.xltx"
If System.IO.File.Exists(ExcelTemplate) = False Then
MessageBox.Show("Cannot locate the BoM Excel Template. Make sure it is saved under the "  _
& "name 'EDT_T-PA25-DT200_BoM' in the current project template folder" & vbNewLine _
& vbNewLine & vbNewLine & vbNewLine &"Click OK to open the Template folder", "BoM Excel template unavailable")
Shell("explorer.exe " & TemplateFolder, vbNormalFocus)
Exit Sub
Choice = InputRadioBox("Select the BoM type", "Phase BoM", "KIT BoM", True, Title := "Export BoM")
oPath = ThisDoc.Path
oName = ThisDoc.FileName(False) 'without extension
Dim oDate As String = Now().ToString("yyMMdd-HHmm_")
oDate = oDate.Replace(":", "")  ' & " - " & TypeString
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
Dim oBOMView As BOMView
xlApp = CreateObject("Excel.Application")
'comment out or change to false
'in order to not show Excel
xlApp.Visible = False
workspace = ThisDoc.WorkspacePath()
xlWorkbook = xlApp.Workbooks.Open(ExcelTemplate)
Dim row As Integer
row = 4
If Choice Then
'get target folder path
oFolder = oPath & "\" & oDate & oName & " Phase BOM"
oBOMView = oBOM.BOMViews.Item("Structured")
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
xlWorksheet = xlWorkbook.Worksheets("KITs List")
xlWorksheet.Activate
oBOMView.Sort("Part Number", True)
oBOMView.Renumber(1, 1)
  Call QueryBOMRowProperties(oBOMView.BOMRows, xlApp, xlWorkbook, xlWorksheet, row)
	oFolder = oPath & "\" & oDate & oName & " KIT BOM"
xlWorksheet1 = xlWorkbook.Worksheets("Cover")
xlWorksheet1.Activate
xlWorksheet1.Range("BD21").Value = iProperties.Value("Project", "Part Number")
xlWorksheet2 = xlWorkbook.Worksheets("Verification")
xlWorksheet2.Activate
xlWorksheet2.Range("B4").Value = Now().ToString("dd/MM/yy")
'Check for the folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
Dim Filename As String = oFolder & "\" & oName & ".xlsx"
'If you want to save the workbook in a specified name
xlWorkbook.SaveAs(Filename)
xlWorkbook.Close
xlApp.Quit
'Show the folder
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'Open the folder containing the new files
Shell("explorer.exe " & oFolder, vbNormalFocus)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ByVal xlApp As Object, ByVal xlWorkbook As Object, ByVal xlWorksheet As Object, ByVal row As Integer)
For i = 1 To oBOMRows.Count
Dim bRow As BOMRow
    bRow = oBOMRows.Item(i)
	Dim rDoc As Document
	rDoc = bRow.ComponentDefinitions.Item(1).Document
	 Dim oPartNumProperty As Inventor.Property
	If rDoc.DocumentType = kAssemblyDocumentObject And _
		rDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.Contains("K") Then
		Dim docPropertySet As PropertySet
		docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
		customprop = rDoc.PropertySets.Item(“Inventor User Defined Properties”)
		xlWorksheet.Range("A" & row).Value = docPropertySet.Item("Part Number").Value
		xlWorksheet.Range("B" & row).Value = docPropertySet.Item("Description").Value
		Try
			xlWorksheet.Range("C" & row).Value = customprop.Item("Frame Height").Value
		Catch
		End Try
		Try
			xlWorksheet.Range("D" & row).Value = customprop.Item("Frame Width").Value
		Catch
		End Try
		xlWorksheet.Range("E" & row).Value = bRow.ItemQuantity
		xlWorksheet.Range("F" & row).Value = bRow.ComponentDefinitions.Item(1).Document.ComponentDefinition.MassProperties.Mass
		row = row + 1
		If Not bRow.ChildRows Is Nothing Then
                    Call QueryBOMRowProperties(bRow.ChildRows, xlApp, xlWorkbook, xlWorksheet, row)
Next
End Sub
but whenever i run this, i am still getting only the top level assembly in the excel. childrens are not exporting to the BOM
But whenever i run this, i am still getting only the top level assembly in the excel. Corresponding children's are not exporting to the BOM
Could anyone please help me with this. i don't know whether it is due to any error in ilogic rule.
daltonNYAW9
Is the "row" value keeping up when you find 'ChildRows'?
try changing how the row variable is passed from byVal to byRef
ByRef row As Integer
bradeneuropeArthur
You need to loop also for the childrows!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
