Add-in load order
Add-in load order
MattH_Work
Add-in load order
MattH_Work
Is there a trick to dictating the 'correct' order for addins to load?
The final intention is to have multiple command buttons in a custom ribbon panel, in the correct order
Cheers
Matt
MattH
Product Design Collection 2026
Vault Pro 2026
etaCAD
Hi Matt,
I think there is a relation between the loading sequence and the GUID of the add-in.
Smaller GUIDs loads first.
I have the info from this post (German).
Andreas
Andreas
etaCAD
bradeneuropeArthur
Did you find the solution?
I try to load my add in when the Vault add in has already been loaded.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
CattabianiI
Do we have an official answer? Or someone that tested it out?
Rene_Gerlach
Hi Matt,
you can try an other way.
Add you commands in the ApplicationEvents.OnReady
"This event fires (only once) after Inventor has completed its initialization. This includes initialization of all the Add-ins loaded at startup"
Rene
