IDW to DWG
IDW to DWG
IDW to DWG
Hi
I have a question. How do I get colors from IDW to DWG, when exporting, I have a sketch symbol with color that is being exported, but objects that are in the view are not exported with colors. Why not. ? See attached file
Hope that you can help.
- Pia
FDS - 2016
Rob67ert
Hi there and welcome to this forum.
Can you show a screenshot form the colors they should be?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Hi there 🙂
Thanks and
See attached screen shot.
-Pia
Rob67ert
That is the way Inventor works.
The view in Inventor is the representation of the part or assembly.
If you make a DWG from it, only the lines will be converted.
To have that in AutoCAD you need a hatch to give it a solid color.
(If you make a PDF you will get the solid view)
Robert
Hi Robert
Thanks for your reply, not the answer I was hoping for.
Perhaps it is possible to do a illogic code for this ?
-Pia
Rob67ert
If you make it an Inventor DWG you will get the color.
But that is not the AutoCAD DWG you like to have.
Robert
Nope.
-Pia
