3D PDF template customization
I am trying to create a custom template for a 3D PDF that will support reduced dimension drafting. I would like to have a multiple sheet drawing that allows me to provide traditionally drafted views in addition to the 3D pdf sheet (to ease our way into MBD).
Has anyone gone down this road already? Can anyone lead me to tips on template customization?
Thanks!
Chris
MechMachineMan
I would have tried this, first off....
http://lmgtfy.com/?q=Inventor+%2B+3d+pdf+customization
Lookin' like there's a nice pdf in the first link with some info.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for the response. I'd found that PDF and it got me off to a good start.
I'm still looking specifically for a way to create a combined drawing with traditional AND 3D PDF sheets.
Combining 'normal' pdf and 3D pd different ways.
1) Manually by copy and paste a 3d pdf sheet into a normal pdf. This 3d pdf will be a new sheet in the normal pdf.
2) Adobe adopted a kind of Java Script which can be used inside a pdf file. I think are options available to make some code inhere to include two documents
