Part name based on parameter values
Hi, I am fairly new to inventor & just getting to grips with ilogic & have a question;
I have a simple ilogic driven part, which upon opening, the form opens & I can type in (say) Project number, Height, Width, & Length, & the part updates.
What I would really like to be able to do next is to have a rule that saves the part with a name that is based on the project number plus the parameters (h**, w**, l**) that set the dimensions of the part. So the part name would look like "Project123 part H**W**L**"
How is the best way to achieve this? (simply!)
TIA
Mark
JaneFan
Hi Mark,
This might be what you need. Make sure you have parameters Length, Width and Height in your part model, then run the iLogic rule:
Dim filename As String
filename = iProperties.Value("Project", "Part Number") + _
            "_H" + CStr(Parameter("Height")) + _
            "_W" + CStr(Parameter("Width")) + _
            "_L" + CStr(Parameter("Length")) + ".ipt"
ThisDoc.Document.SaveAs("c:\temp\" + filename, True)
Jane Fan
Inventor/Fusion QA Engineer
