Add existing form under Global Forms
If I have the .xml file of a form, how can I add this form to my Global forms?
Under global forms you can right-click and select open containing folder, but you can't add a form 🤔
bradeneuropeArthur
Think that you need to deference the .dll file instead of the .xml file!
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
