On one of many computers add-ins fail to load and show in add-ins list in Invent
PetterMoldestad
Message 1 of 8
PetterMoldestad
Hello.
I've written some add-ins for Inventor. They usually work as intended. But occasionally (maybe in 1 of 50 installations) one of the add-ins doesn't show on that computers add-ins list in Inventor. Uninstall and reinstall doesn't help. Does anyone have an ide what the issue might be? Or even better how to fix it?
Replies (7)
Message 2 of 8
HideoYamada
Hi petter,
Is the Inventor version same as the others?
Is .net Framework which version is required by add-in installed?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 8
PetterMoldestad
In the latest case now, yes Inventor version are the same. Yes, latest .NET installed.
Message 4 of 8
HideoYamada
Does the certain *.addin file exist in the certain directory?
Try copy the *.addin file from the machine which add-in works to the machine which has issue.
I found that Inventor see only the *.addin file to decide adding to the list of the AddIn Manager.
Even if *.dll doesn't exist, the name of add-in is listed in AddIn Manager.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 5 of 8
PetterMoldestad
Hello Hideo.
Thank you for your replies. I don’t produce an .addin file. I just make a dll file and register that with RegAsm.exe.
Message 6 of 8
HideoYamada
I have started to create add-ins in the last few years, so my knowledge is limited to registry free add-ins.
Sorry for not helping you, but I think the cause is around there.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 7 of 8
PetterMoldestad
Ok. Thank you very much for trying to help with your replies.
Message 8 of 8
PetterMoldestad
I needed to update to a newer RegAsm.exe. Then it worked again.
