Activate a sheet in a non visible file.
shastu
Advisor Advisor
shastu
You can do a lot of things with a drawing without ever visibly seeing it.  For example,
Set oNewDocument = ThisApplication.Documents.Open("FullFileNamePath", False)
My question is how do you activate the sheets when it is not showing?
For Example,  I have a For statement to delete the title block on each sheet:
For oSheetNumber = 1 To oDoc.Sheets.Count
oDoc.Sheets(oSheetNumber).Activate
Set oSheet = ThisApplication.ActiveDocument.ActivateSheet
oSheet.TitleBlock.Delete
Next
If the drawing is open and visible this works fine.  If the drawing is open but not visible the line
throws an error saying the Object variable is not set.
If I just comment it out, the titleblock on the active page is deleted but when I go to the next page I get an error upon the delete.
MechMachineMan
The answer is that you don't need to activate a sheet to perform an operation on it.
Grabbing the sheet and assigning it to the variable still references the same sheet.
All calling the "Activate" method does is make it visible to the user.
Therefore, your code to do the same should be:
Set oDoc = ThisApplication.Documents.Open("FullFileNamePath", False)
            Set oSheet = oDoc.Sheets(oSheetNumber)
Next
or use a for each loop if you don't need to keep track of which sheet it currently is on;
For Each oSheet in oDoc.Sheets
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
shastu
What about deleting a Drawing Resource when the sheet is non visible?  When it is visible I use the DoSelect method, but when it is not visible this does not work.  Here is what I was wanting to accomplish:
 Set oPane = oDoc3.BrowserPanes.ActivePane
 Dim oDoc3Node As BrowserNode
 Set oDoc3Node = oPane.TopNode
 Set oDrawingResourceNode = oDoc3Node.BrowserNodes.Item("Drawing Resources")
 Dim oSheetFormatsNode As BrowserNode
 Set oSheetFormatsNode = oDrawingResourceNode.BrowserNodes.Item("Title Blocks")
 ' Get the specified sheet format node.
 Dim oSheetFormatNode As BrowserNode
 Set oSheetFormatNode = oSheetFormatsNode.BrowserNodes.Item("ANSI A")
 ' Select the node in the browser.
 oSheetFormatNode.DoSelect
 ' Execute the delete command.
 ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute
shastu
Never mind.  I got it.
 Dim oBorderDefinition As BorderDefinition
 Dim oTitleBlockDefinition As TitleBlockDefinition
 For Each oTitleBlockDefinition In oDoc.TitleBlockDefinitions
    If oTitleBlockDefinition.Name = "ANSI A" Then
        oTitleBlockDefinition.Delete
 Next
