How Can I Simplify this Code and Retain it's Functionality?
I've created a basic If...Then...End If command to change the sheet size across all sheets in the idw file and zoom-extents on all sheets.  BUT, I've come to find out that if I delete one of the sheets, it kinda-sorta messes with the flow (the message "ThisDrawing.Sheet: No sheet named XXXX was found") and the zoom-extents rule does not run.
So, I was wondering if there's any way to possibly simplify the code such that it won't require the precise names of each individual sheet for it to work.  This way, if the user deletes one sheet, the rule can still maintain the same functionality.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 20052 StartFragment: 314 EndFragment: 20020 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
If Sheet_Size = "Letter (8.5 x 11)" Then
ActiveSheet = ThisDrawing.Sheet("Primary Plant:1")
ActiveSheet.ChangeSize("A", MoveBorderItems := True)
ActiveSheet = ThisDrawing.Sheet("Primary Plant:2")
ActiveSheet = ThisDrawing.Sheet("Alternate Plant 1:3")
ActiveSheet = ThisDrawing.Sheet("Alternate Plant 1:4")
ActiveSheet = ThisDrawing.Sheet("Alternate Plant 2:5")
ActiveSheet = ThisDrawing.Sheet("Alternate Plant 2:6")
iLogicVb.RunRule("Auto-Zoom to Extents")
ElseIf Sheet_Size = "Tabloid (11 x 17)" Then
ActiveSheet.ChangeSize("B", MoveBorderItems := True)
Owner2229
Hey try one of these:
A) For specific sheets only:
Sub Main()
        ChangeSheet("A")
        ChangeSheet("B")
End Sub
Sub ChangeSheet(NewSize As String)
    ThisDrawing.Sheet("Primary Plant:1").ChangeSize(NewSize, MoveBorderItems := True)
    ThisDrawing.Sheet("Primary Plant:2").ChangeSize(NewSize, MoveBorderItems := True)
    ThisDrawing.Sheet("Alternate Plant 1:3").ChangeSize(NewSize, MoveBorderItems := True)
    ThisDrawing.Sheet("Alternate Plant 1:4").ChangeSize(NewSize, MoveBorderItems := True)
    ThisDrawing.Sheet("Alternate Plant 2:5").ChangeSize(NewSize, MoveBorderItems := True)
    ThisDrawing.Sheet("Alternate Plant 2:6").ChangeSize(NewSize, MoveBorderItems := True)
End Sub
B) For all sheets:
Sub Main()
        ChangeSheet("A")
        ChangeSheet("B")
End Sub
    For Each oSheet As Sheet In ThisDoc.Document.Sheets
oSheet.ChangeSize(NewSize, MoveBorderItems := True) Next iLogicVb.RunRule("Auto-Zoom to Extents") End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Curtis_Waguespack
Hi t.desrosiers,
It looks like Owner2229 posted while I was looking at this, but here is another option.
I hope this helps.
Curtis
Dim oSize As Boolean
oSize = InputRadioBox("Select size:", "Letter (8.5 x 11)", "Tabloid (11 x 17)", True, "iLogic")
If oSize = True Then
Else
'^^^ the code above is just for testing
Dim oCurrentNumber  As Sheet
oCurrentNumber = ThisDoc.Document.ActiveSheet
For Each oSheet In ThisDoc.Document.Sheets
	oSheet.Activate
	oSheet.Update
Next
oCurrentNumber.Activate
Curtis, your solution worked like a charm.  Thanks!
