ilogic rule for sheet metal weight
doug.johnston
doug.johnston
Hey all,
I am just getting into understanding some basic iLogic and now I've hit a wall and can't figure out how to program / place an equation to get the "blank weight" of a piece of sheet metal.
I am linked to an Excel spreadsheet that has the weights I need (lbs/sq.ft & lbs/sq.in.)
I just cannot figure out how to ,or where to put a formula to get the answer into a usable parameter (custom and/or user) in my sheet metal template.
The formula I have tried is: "extents_length x extents_width x WEIGHT_2"   with
extents_length = total length in inches
extents_width = total width in inches
WEIGHT_2 = sheet metal weight in lbs/sq.ft.
I have attached a picture of the user parameters that I have in the template and (2) tries at creating an equation (both as a text and as a number parameter).
Any assistance would be appreciated ...
Doug Johnston
It's not easy maintaining this level of insanity !!!!!
JarFu
Hi Doug,
From the error figure you attached, the Unit/ Type should not be Unitless (ul), we need set a valid unit.
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Yijiang.Cai
If you want to get the value on “BlankWeight_DJ", it is fine to use "ul" as the unit. Please use the iLogic code lines as below -
BlankWeight_DJ=extents_length * extents_width *CDBL(WEIGHT_2)
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
