Access Multi value List from outside the Part/Assembly
cencinaNB2ET
cencinaNB2ET
Hi All,
I'm trying to Open a file from another file and access its multi-value list to manipulate it as an Array list.
So far I can only change the iproperties and make it run rules inside of it but not access multi value lists directly.
Is there a way to achieve this??
SyntaxEditor Code Snippet
Dim Save_Path As String
Dim Folder As Integer
Dim File As String  = "E:\Engineering Projects\Project A\Factory Components\Manufactured Components\Standard Topbar\Standard Topbar.iam<CV>"
oFile = ThisApplication.Documents.Open(File, False)
Dim oOcc As ComponentOccurrence ' singular
Dim Occurrences As ComponentOccurrences
Dim oSubCompOcc As ComponentOccurrence
Dim userParams As UserParameters
Dim param As Parameter
oAsmDoc =  oFile
oAsmDef = oAsmDoc.ComponentDefinition
userParams = oAsmDef.Parameters.UserParameters
Dim This_FileName As String = oAsmDoc.FullFileName
Dim Directory As String = Left(This_FileName, InStrRev(This_FileName, "\"))
Dim Main_Materials_QTY As New ArrayList
Main_Materials_QTY = MultiValue.List("Heading_Materials_QTY")
For Each element In Main_Materials_QTY
MessageBox.Show( element, "")
Next
oFile.Save
oFile.Close
iLogicVb.UpdateWhenDone = True
bradeneuropeArthur
In what language?
Vba
Vb.net
I logic
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
