how to convert cad format (like step, igs ) to inventor files using macros
lohithna
Message 1 of 10
lohithna
i have to convert in bulk , can please help on this ,
or else solid works to inventor files in bulk using macro if any macro plaese share
exaple file i attched
Replies (9)
Message 2 of 10
bradeneuropeArthur
What do you need excactly?
You need to convert the attachrd files to inventor files?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
lohithna
for example i attched a file of solidworks part in above post , similar all files as to convert ti .ipt using macro
Message 4 of 10
bradeneuropeArthur
What other files?
We need thst to help you I assume!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
lohithna
below image refere . requried some macro for solid works part to inventor .ipt  files
Message 6 of 10
lohithna
anyone help on this
Message 7 of 10
bradeneuropeArthur
We need files to help.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
Frederick_Law
Message 9 of 10
lohithna
please find attached file
Message 10 of 10
lohithna
Using task scheduler, solidworks parts and assemblies can be converted into inventor part and assemblies. But iproperties given in the solidworks is not importesd into inventor files. Please provide the solution for that. I want all the solidworks properties into inventor files also.
