Patran vs Nastran: What are the differences?...
george_ionita52KAC
george_ionita52KAC
What are the main differences between Patran vs Nastran?
Do they work together?
Thank you!
John_Holtz
Autodesk Support
Autodesk Support
Hi @george_ionita52KAC
According to Google, "Patran is the world's most widely used pre/post-processing software for Finite Element Analysis (FEA), providing solid modeling, meshing, analysis setup and post-processing for multiple solvers".
In other words, Patran is an alternative to the Inventor Nastran environment inside Inventor.
When someone mentions Nastran, they generally mean the solver that calculates the results of an analysis. Those are two separate things. You create the model using (fill in the blank), solve the analysis using Nastran, then view the results using (fill in the blank).
So, what is your (fill in the blank)? Are you using Inventor and the Inventor Nastran environment, or are you using Patran?
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
george_ionita52KAC
John, thanks for your reply.
Please, excuse my ignorance:
- What did you mean by "(fill in the blank)"?.....................
John_Holtz
Autodesk Support
Autodesk Support
"fill in the blank" means that you replace those words with the program you are using to create the analysis. I do not know what software you are using to create the analysis. Are you using Inventor Nastran? Patran? Something else?
Because you asked about Patran, that makes me think you are using Patran to create the model and Inventor Nastran to run the analysis.
John
John Holtz, P.E.
Autodesk, Inc.
george_ionita52KAC
I use Autodesk Inventor 2025.......
