Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Patran vs Nastran: What are the differences?...
4 REPLIES 4
george_ionita52KAC
551 Views, 4 Replies
What are the main differences between Patran vs Nastran?
Do they work together?
Thank you!
4 REPLIES 4
Hi @george_ionita52KAC
According to Google, "Patran is the world's most widely used pre/post-processing software for Finite Element Analysis (FEA), providing solid modeling, meshing, analysis setup and post-processing for multiple solvers".
In other words, Patran is an alternative to the Inventor Nastran environment inside Inventor.
When someone mentions Nastran, they generally mean the solver that calculates the results of an analysis. Those are two separate things. You create the model using (fill in the blank), solve the analysis using Nastran, then view the results using (fill in the blank).
So, what is your (fill in the blank)? Are you using Inventor and the Inventor Nastran environment, or are you using Patran?
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John, thanks for your reply.
Please, excuse my ignorance:
- What did you mean by "(fill in the blank)"?.....................
"fill in the blank" means that you replace those words with the program you are using to create the analysis. I do not know what software you are using to create the analysis. Are you using Inventor Nastran? Patran? Something else?
Because you asked about Patran, that makes me think you are using Patran to create the model and Inventor Nastran to run the analysis.
John
John Holtz, P.E.
Autodesk, Inc.
I use Autodesk Inventor 2025.......
