Problem: The scale of the hatching changes relative to the parent view and has to be changed manually (or with iLogic Rule) each time.
According to the ISO and DSTU standards given in the textbooks, the hatching should be the same as in other images of this part.
When you build a section with a scale, the hatching is performed correctly (just like on the parent view).
The main problem is that when we use scaling views, we should have the same approach to hatching.
Now (including the latest version of IV2025.1), when building sections with scaling in/out, the hatching scale does not change (A-A), but when building a hatching element in Detail View (B), it does (see Fig. below).
This difference cannot be explained; the hatching scale in the enlarged views should be the same.
The previous request at https://forums.autodesk.com/t5/inventor-ideas/auto-scaled-hatches/idi-p/5568621 was Archived with comment “… it is unclear what the request is …”
