Ability to change diameter dimension to raidus and viceversa after placement
as you dimension you can decide if your dimension is a diameter or a radius dimension (in sketch and also in drawing).
Would like ability to change diameter dimension to raidus dimension and viceversa after dimension has been placed.
Alex
7 Comments
A_Sima
Hi all,
I propose 2 check boxes to be added to the Edit dimension check box. I would prefer to have these 2 options here in the beginning and not to take another step more clicking the RMB to select what I could select from start in the dialogue box. (see the attached image)
And, yes I would prefere to have the option to be able to change anytime a dimension from Radius type to Diameter type (in the sketch environment)
Tags (1)
YES PLEASE!!!! Ive had a lot of time where this would be nice! it get irritating especially if you put text in it then realize you made a radius instead of a diameter
This would be a very good idea
Please add the functionality to change a created dimension on a drawing from radius to diameter or horizontal to aligned.
This should be allowed in drawings and part sketches.
Yijiang.Cai
It has been tracked as [INVGEN-56677]
Yijiang.Cai
Status changed to: Accepted
@Anonymous @Anonymous @Anonymous @Anonymous @A_Sima
we are investigating on this idea, and some progress is made. You can access the feedback community page to see what we have done
You could access the page below to understand how to join the Beta at https://forums.autodesk.com/t5/inventor-forum/inventor-feedback-beta-project-how-do-i-get-access/td-...
River
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2023.1. Please review the Inventor 2023.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
