What is wrong with this file?
jeremy_wasserstrass
jeremy_wasserstrass
Is there a way to figure out what is wrong with the attached file? I get the following message when trying to open it.
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
hollypapp65
2022 file updated to 2026.  Something went wrong with the migration.
Do you still have the old 2022 file?
jeremy_wasserstrass
No I do not have the previous version. Even the ipt in the old versions folder exhibits the issue.
CGBenner
@jeremy_wasserstrass
This sounds like a pipe fitting... is it possible that the part (or one close to it) might be in your Content Center?  What kind of Tee is this?
It's possible, since this file appears to be corrupt, that you might be able to find and modify something that is in your Content Center that is close?
Chris Benner
jeremy_wasserstrass
Unfortunately this is a custom conduit fitting we do for an electrical contractor in the area so there's no comparable part in the content center. Luckily the drawings associated do open so if IT can't find me a version that will open it shouldn't be too bad to rebuild it.
