Can’t re-insert Title Block after deleting in Inventor Pro 2024 (ISO metric template)
amir.dirbazC27RL
Observer Observer
amir.dirbazC27RL
Observer
Observer
Hi everyone,
I’m having an issue with Autodesk Inventor and title blocks. I’m using the standard ISO (metric) drawing template.
  • When I delete the default title block from a sheet and then try to insert a new one, nothing happens.
  • Right-click → Insert on the title block in Drawing Resources → Title Blocks doesn’t respond at all.
  • Editing the existing block works fine, but adding a fresh one seems impossible.
  • I already checked for “Sketch only” geometry and stray points in the bottom-right corner, but found nothing unusual.
Has anyone else run into this? Could this be a template problem or a possible Inventor bug?
Thanks in advance for your help!
@amir.dirbazC27RL Your post title was modified to add the product name and version and to increase findability - CGBenner
johnsonshiue
Hi! I suspect the Title layer is turned off. Go to Manage -> Styles Editor -> Layers -> Title. Make sure it is set to be visible.
Many thanks!
Software Test Engineer
kacper.suchomski
What happens when you click RMB -> Insert
Kacper Suchomski
