Inventor Forum
VBA / Macros not initiating
5 REPLIES 5
266 Views, 5 Replies
Anyone has problem with VBA and Macros command not working in Inventor?
I am using INV2014. When I click-on the icon it does not initiate neither gives any error details?
5 REPLIES 5
Xun.Zhang
Hi @Anonymous,
Have you tried with Inventor reset utility? Windows start, searching Inventor reset utility and then select the version to reset. if it does not work, then try to repair program via control panel.
Xun
in reply to: Xun.Zhang
@Xun.Zhang wrote:
Hi @Anonymous,
 @Xun.Zhang
Will this delete any changes to styles and standard libraries?
johnsonshiue
Hi! Are you on Win 10? If yes, I don't recall Inventor 2014 supports Win10. There might be shared components required for Inventor 2014 not available on Win 10.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
Hi!
Using it on Win7.
Thanks!
johnsonshiue
Hi! Then I would try Repair Install. Go to Control Panel -> Programs and Features -> find Autodesk Inventor Professional 2014 -> right-click on it -> Uninstall/Change -> Repair Install.
It looks like a shared component necessary for VBA to run was not installed properly.
Many thanks!
