Inventor Forum
Trouble extruding a parametric curve
9 REPLIES 9
Message 1 of 10
789 Views, 9 Replies
I am trying to extrude the shape which I have made a 2D Sketch of, as seen. The end goal is to create a ramp of sorts, however I think the curve is causing some issues. It is a curve created from a the parametric equation
x: t-sin(t)
y: 1-cos(t)
I have tried extruding, revolving, lofting, free forming, and sweeping but every time I try I get the error "the attempted operation did not produce a meaningful result" I have checked in the sketch doctor which finds no problems, so I am at a loss. Any help would be appreciated!sc3.png
9 REPLIES 9
Message 2 of 10
jhackney1972
Please attach your part to your question so others can help.  An equation curve will normally only create a single sketch entity.  Your screen capture seems to show a curve box of some type.  You can extrude a single sketch but it will be a surface only, not a solid.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 10
in reply to: jhackney1972
I have now attached the file with my part. If the curve can only be a surface, does that mean there is no way to create a ramp with that specific curvature? Thanks for your quick reply!
Message 4 of 10
jhackney1972
Your equation curve is not planar.  If you look at the 'Transformation" values, you will see a slight rotation.  I point this out in the screencast.  The solution is quick, unless you want to try and figure out the correct equation curve, create a new plane above the sketch plane, and project all the geometry.  This removes the rotation value from the equation curve.
Take a look at the screencast and you will understand.
John Hackney
Retired
Message 5 of 10
johnsonshiue
Hi John,
Many thanks for providing the alternative solution! I am surprised that the 2D curve is not planar. It should not be the case. I suspect there is a singularity on the equation driven curve prohibiting the profile to be created properly. Somehow, projecting it as a reference curve "fixes" it. I need to take a closer look. Something is wrong here.
Thanks again!
Software Test Engineer
Message 6 of 10
johnsonshiue
Hi! Indeed, this does not look right to me. It should work. Besides John's workflow, you could also use Boundary Patch command to create a patch surface. Then use Thicken command or project the surface loop and create an extrusion.
Many thanks!
Message 7 of 10
Awesome. Thank you all!
Message 8 of 10
Xun.Zhang
Share a quick update, it was tracked by ticket INVGEN-8828.
Xun
Message 9 of 10
BRUND
in reply to: Xun.Zhang
Just wanted to say thanks for the post.  I find it pretty odd that your equation curve wasn't planer.  I did an involute curve equation and I would have expected a planer result too.  I would be interested in a more in depth answer.
Message 10 of 10
johnsonshiue
in reply to: BRUND
Hi! Any 2D sketch is planar. The reason why this particular case fails to extrude is due to some high curvature area on the curve that cannot form a profile properly. Unfortunately, the defect INVGEN-8828 was closed as a limitation. I don't see a simple fix to this case.
But, I am not sure if your case is the same as this one. If possible, please share the file here or send it to me directly johnson.shiue@autodesk.com. I can help take a look to see if the issue is the same and also if there...
Many thanks!
Technology Administrators
