Trouble extruding a parametric curve
Message 1 of 10
I am trying to extrude the shape which I have made a 2D Sketch of, as seen. The end goal is to create a ramp of sorts, however I think the curve is causing some issues. It is a curve created from a the parametric equation
x: t-sin(t)
y: 1-cos(t)
I have tried extruding, revolving, lofting, free forming, and sweeping but every time I try I get the error "the attempted operation did not produce a meaningful result" I have checked in the sketch doctor which finds no problems, so I am at a loss. Any help would be appreciated!sc3.png
Replies (9)
Message 2 of 10
jhackney1972
Please attach your part to your question so others can help.  An equation curve will normally only create a single sketch entity.  Your screen capture seems to show a curve box of some type.  You can extrude a single sketch but it will be a surface only, not a solid.
John Hackney, Retired
Message 3 of 10
I have now attached the file with my part. If the curve can only be a surface, does that mean there is no way to create a ramp with that specific curvature? Thanks for your quick reply!
Message 4 of 10
jhackney1972
Your equation curve is not planar.  If you look at the 'Transformation" values, you will see a slight rotation.  I point this out in the screencast.  The solution is quick, unless you want to try and figure out the correct equation curve, create a new plane above the sketch plane, and project all the geometry.  This removes the rotation value from the equation curve.
Take a look at the screencast and you will understand.
Message 5 of 10
johnsonshiue
Hi John,
Many thanks for providing the alternative solution! I am surprised that the 2D curve is not planar. It should not be the case. I suspect there is a singularity on the equation driven curve prohibiting the profile to be created properly. Somehow, projecting it as a reference curve "fixes" it. I need to take a closer look. Something is wrong here.
Thanks again!
Software Test Engineer
Message 6 of 10
johnsonshiue
Hi! Indeed, this does not look right to me. It should work. Besides John's workflow, you could also use Boundary Patch command to create a patch surface. Then use Thicken command or project the surface loop and create an extrusion.
Many thanks!
Message 7 of 10
Awesome. Thank you all!
Message 8 of 10
Xun.Zhang
Share a quick update, it was tracked by ticket INVGEN-8828.
Xun
Message 9 of 10
BRUND
Just wanted to say thanks for the post.  I find it pretty odd that your equation curve wasn't planer.  I did an involute curve equation and I would have expected a planer result too.  I would be interested in a more in depth answer.
Message 10 of 10
johnsonshiue
Hi! Any 2D sketch is planar. The reason why this particular case fails to extrude is due to some high curvature area on the curve that cannot form a profile properly. Unfortunately, the defect INVGEN-8828 was closed as a limitation. I don't see a simple fix to this case.
But, I am not sure if your case is the same as this one. If possible, please share the file here or send it to me directly [email protected]. I can help take a look to see if the issue is the same and also if there...
Many thanks!
