I found that in the Inventor settings - Manage style editor for dimension . Inventor has option to set tolerance only for both primary and alternate units at a time and doesn't have the option to show tolerance only for Primary units.
Is there any such option in the Manage style editor . Please see the above image for further clarity of the problem
Thankyou
I don't know of any specific setting for this case but maybe you can try following Display Option: Zero Tolerance Display: Suppress Display
That way zero tolerances should not be displayed.
Hope this helps,
Oto Kaleja
heY @okale
Many thanks for the reply . The option that you told is not working . Still the Tolerance of alternate dimensions are displaying as +0 -0
This question has been asked at least twice. In both cases an Autodesk employee provided a useless answer. Again, in both cases, the Autodesk employee failed to respond to the original poster when he/she explained that Autodesk's answer was incorrect, misguided, or otherwise missed the mark.
Hi! Please refer to the reply on the other thread. Indeed, there isn't a workflow to do that in Inventor. Neither prior solutions worked, since the control is only for both (primary and alternate) tolerances, not for just one.
I believe AutoCAD Mechanical offers such workflow. Please use VIEWBASE command in AutoCAD to create associative drawing views to Inventor components. Then annotate accordingly.
Many thanks!
