Is there a way to remove alternate unit tolerances in Inventor 2017
I would like to show both imperial and metric values in my dimensions, but I only want tolerances to be shown in imperial. Is there a way to remove alternate unit tolerances in Inventor 2017.
Xun.Zhang
Hi Sujeet,
Go to Manage tab -> Styles Editor -> Alternative unit, set the style as you want.
Xun
Hi Xun.Zhang,
Thanks for reply. But I want to give tolerance only in imperial units, not in metric.
 Please see attached file as a reference.
Sujeet
davef
I have the same question and wonder why Autodesk's employee (after misunderstanding a very clear question) chose not to reply to the original poster after explaining that Autodesk's first answer missed the mark.
johnsonshiue
Hi Dave,
You are right. I think Xun misunderstood the issue and the proposed solution isn't a solution. Unfortunately, I am not aware of a way to do that.
If you have access to AutoCAD Mechanical, you can actually create associative drawing views of Inventor components  and annotate them in AutoCAD.
Many thanks!
Software Test Engineer
