SP1 has been installed but not according to IV
Paul-Mason
Message 1 of 15
Paul-Mason
Down loaded and installer SP1 Customers without Subscription it ran when through the install BUT when I check to see if it's installed here's what I see
Even used the reset utility and tried to install SP1 again it won't run noting happens.
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Replies (14)
Message 2 of 15
rhasell
Following...
Same here.
Reg
2026.1
Message 3 of 15
karthur1
Paul.
I think that is "normal".  I see the same thing from the Inventor help.  Per the Inventor 2016 R2 Readme file Under Windows > Control Panel > Programs and Features... you should see the Inventor 2016 R2 listed there.
Not exactly sure why they did it that way, but it would have eliminated some confusion if they had made it say R2 there on the help screen.
Kirk
Message 4 of 15
blair
I see the same thing as well. It looks like the R2 removes the last update.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 15
rhasell
I installed SP1 this morning.
I eventually installed R2 over the SP1, which worked. (also this morning)
Notes:
When I installed the Non-Subscription Service pack it did not work, the issue was the same as above.
It was listed in the Add/Remove programs, as SP1 but I don't think it was installed.
Testing:
The only test I did was to do a print of some concrete hatching With "SP1" installed, the hatching did not print, as per the software bug.
I did the same test with R2, this worked, so the conclusion I can come to is that SP1 did not install correctly.
Reg
2026.1
Message 6 of 15
Paul-Mason
This is what I see, Inventor is shown as installed 01/11/2015 that is because after SP1 was not showing I did a "REPAIR INSTALL",I tried to install SP1 again thats when I run into the problem of it NOT INSTALLING on running it just ask if I want to install and then nothng happens. The about STILL shows as in the above screen shot.
Inventor 2026 Pro
Xeon
Message 7 of 15
Paul-Mason
So the NON-SUBSCRIPTION SP1 has definitely NOT INSTALLED correctly or at all as I'm STILL seeing the hatch problem
As printed
As it should be
Inventor 2026 Pro
Xeon
Message 8 of 15
DannyHubbard
Can you post the Inventor 2016 SP1 logs from your TEMP folder?
Also you might check out Baocheng's post from this other post.
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2016-r2-update-customers-with-sub...
Danny
Danny Hubbard
QA Analyst
Message 9 of 15
Paul-Mason
So I EVENTUALLY and NO HELP FROM AUTODESK, got SP1 to install by mucking well un-installing IV installing run once run the downloaded SP1 Non-subscription version.
Shouldn't need to muck around like this, I recall I had to do the same with update 2, now that's ALL my available activations gone anymore buggering around like this and I'll need to muck about more justifying my extra request with Autodesk.
This is BOTH A BLOODY AND UNNECESSARY.
Oh and yes the print, to paper/hard copy hatch problem has been fixed at long last
Inventor 2026 Pro
Xeon
Message 10 of 15
ChrisMitchell01
Hi Paul,
You're correct you shouldn't need to bugger about like that; sorry for the inconvenience. Could you provide us with your install log files as Danny requested, so that we can better understand what didn't work for you ?
If you have future activation issues just let me know & I'll sort it out for you.
Good to hear that the priniting issue is resolved; Thanks for confirming it.
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 11 of 15
Paul-Mason
I can't provide the logs as my systems housekeeping program auto deletes them when there more than 12 hours old. AND for some unknown reason your system has STOPPED sending me emails, it looks as if I've been unsubscribed for ALL topics and I can't re-subscribe to them thus the late reply to this message.
Inventor 2026 Pro
Xeon
Message 12 of 15
ChrisMitchell01
Ok Thanks Paul.
You seem to be using 2 different accounts, with different emails, to post to some of the forum topics. One is called Mason-Paul (email account is mason.XXXXXXXX@btinternet.com) & the other is called roc2328 (email account is mason.XXXX@btinternet.com). Does that explain why you're not getting notifications ?
-Chris
Chris Mitchell
Message 13 of 15
BaochengWu
Hi Mason-Paul,
Sorry for your inconveniences. Your issue looks very similiar to a known issue. could you try below steps to see if your issue is solved?
1. Remove Inventor 2016 English Language Pack SP1
Msiexec.exe /uninstall {C2B4B6F5-2010-1033-0064-E0CB94366A9C} /package {7F4DD591-2064-0001-1033-7107D70F3DB4} /qb
2. Remove Inventor 2016 SP1
Msiexec.exe /uninstall {C2B4B6F5-2000-1000-0064-E0CB94366A9C} /package {7F4DD591-2064-0001-0000-7107D70F3DB4} /qb
3. Remove Inventor 2016 Update 1 (Inventor SP1 supesedes it and you can also install it again later)
Msiexec.exe /promptrestart /qb /uninstall {D9AD67F6-F5D8-4377-8826-01687953EF10} /package {7F4DD591-2064-0001-0000-7107D70F3DB4} SETUP=1
4. Install SP1 again.
Baocheng
Baocheng Wu
SW Engineering Manager
Message 14 of 15
BaochengWu
Hi rhasell,
The issue that failed to install SP1 may be related to legacy update1. Could you please try below steps to see if it helps?
1. Remove current partial R2 from add/remove panel by clicking Autodesk Inventor 2016 R2. Skip it if you've done.
2. Remove Inventor 2016 English Language Pack SP1
3. Remove Inventor 2016 SP1
4. Remove Inventor 2016 Update 1 (Inventor SP1 supesedes it and you can also install it again later)
5. Install R2 or SP1 again.
Baocheng
Baocheng Wu
Message 15 of 15
Paul-Mason
I already un-installed & REINSTALLED ran it once ran the SP1 exe file it installed no problem.
Waht exactly the problem was I'VE NOT GOT A CLUE but this problem needs looking into, I also had the SAME problem with update2
Inventor 2026 Pro
Xeon
