Inventor Forum
Show Tolerance without Dimension Value
2 REPLIES 2
ilyas_drawbridge
187 Views, 2 Replies
Hi Everyone,
In my drawings, I'd like to display a dimension as text with tolerance values like the image below.
1. If I use Hide Dimension Value in the text tab, it doesn't show the tolerance
2. If I use Override Displayed Value in the Precision and Tolerance tab, it doesn't allow non-numeric input.
Any thoughts?
Ilyas
Tags (2)
Labels (2)
2 REPLIES 2
Do a combination of overwrite dimension value and input a text in the text field like this
Edit: Just realised you might not want the numbers at all.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
There is a way, if you always follow your L with an non-zero integer:
MichielValcke_3-1720615347410.pngMichielValcke_4-1720615384934.pngMichielValcke_5-1720615421958.png
